Over tightened filters....
Discussion in 'Volvo Forum' started by 6cuda6, Nov 14, 2020.
  1. 6cuda6
    6cuda6 Light Load Member
    259
    176
    Oct 9, 2020
    Guys, just a reminder....do not over tighten your filters....someone put the fuel filter (on my new to me truck) so tight i'm not sure if i'm going to be able to get it off. Its on so tight that currently its twisting the can trying to get it to turn.
    I'm actually going to have to get my 8" jaw Chanellock slip joint plyers from my tool box in storage as a last ditch effort to get it off....if those dont work i may have to cut it off in pieces to get to the mount then use a punch and hammer to drive it off. :mad:
  3. 062
    062 Road Train Member
    6,338
    33,982
    Oct 20, 2013
    Strap wrench hasn’t failed me yet. First oil change on my truck I had to use a 3/4 impact on the drain plug. The fuel filter was a strap wrench with a 2’ ratchet.
    KB3MMX Thanks this.
  4. bad-luck
    bad-luck Road Train Member
    3,442
    6,349
    Nov 16, 2013
    Baltimore, Maryland
    If I get a PM at a truck stop they always over tighten my filters for some reason. In fact, once they over tightened the primary fuel filter so much that it broke the weld on the shaft and when attempting to take it off the filter and shift would turn. They paid for the filter housing and put it on, but it was still a pain in the butt!
  5. 6cuda6
    259
    176
    Oct 9, 2020
    This one is on so tight the strap wrench didnt even touch it.....had a bit of movement (i think) using Chanellock filter plyers with a piece of pipe over them but space is too limited etc...
    No way you could ever deal with this in a parking lot while hauling load.
  6. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    I've used two filter wrenches at the same time pulling on one and pushing on the other, good luck
    blairandgretchen Thanks this.
  7. AModelCat
    164,927
    Worst thing is they write the installation instructions right on the filter 99% of the time.
    A little lube on the gasket is EXTREMELY helpful as well. Installed to the proper tightness with a dry gasket is as much of a b#### to remove as an over-tightened one.
  8. Shawn2130
    Shawn2130 Heavy Load Member
    896
    1,900
    Sep 20, 2015
    Southern Ontario
    Sometimes I’ve had to drive a large screw driver through the filter near the top as I’ve crunched the filter body.
    Dino soar, 86scotty and daf105paccar Thank this.
  9. pavrom
    pavrom Road Train Member
    3,217
    7,422
    Apr 29, 2012
    NE illinois
    I service mine in one shop over 3 years ...never nad any issues.
  10. 6cuda6
    259
    176
    Oct 9, 2020
    The worst of it is as another said...its written right on the can how far to turn it PLUS they put numbers on it so you dont over do it....
    Jeeze, a drop of oil or grease on the gasket, spin it on till it stops, then a little twist and its good to go....not rocket science but it seems like it is to some people.....no tools are needed to put it on and if it leaks once put on as per instructiond you probably have the wrong filter!
    Deere hunter and Lazer Thank this.
  11. 86scotty
    86scotty Road Train Member
    4,723
    12,976
    Aug 27, 2017
    Appalachia
    Shops overtightening them is paranoia about legal liability. We've all heard of oil filters and drain plugs falling out of cars after visits to the quickie lube.
    This is another reason I really like to do my own services.
    blairandgretchen and D.Tibbitt Thank this.
