Over weight on steers
Discussion in 'Volvo Forum' started by thatguyfrombk, Mar 30, 2024.
  1. thatguyfrombk
    thatguyfrombk Light Load Member
    52
    34
    Oct 17, 2020
    So I just got this VNL 860. I’m empty with a full tank. I scaled out three times already today and I keep coming up at 12400 on my steers. Again this is a brand new truck with only 2000 miles on it and I’m truly stumped as to what and why this is happening. 5th wheel is slid all the way back truck has an apu that weighs only 242lbs but I’m still baffled to the steers. Tires are the Bridgestones that come on the truck G ply at 6175lbs steer is max at 12500.
  3. Stringb8n
    Stringb8n Road Train Member
    1,705
    2,232
    Sep 27, 2015
    13,200 steer axle weight rating. Look at the door jamb, the sticker there. You should be just fine so long as you're not over anywhere else.
    EDIT: Nevermind, I read the whole post just now and saw your tire ratings. Sorry, my brain stopped reading it before I replied at "12400 on my steers"
    MACK E-6 Thanks this.
  4. drivingmissdaisy
    drivingmissdaisy Road Train Member
    1,945
    3,315
    Jun 10, 2019
    Does it have a cattle guard on the front?
    If you have an APU you're ok just don't go over on any other axle.
  5. thatguyfrombk
    52
    34
    Oct 17, 2020
    No guard up front. I haven’t yet taken a load on this new truck yet so I’m assuming I’ll become even heavier on the steers which I’m still baffled about
  6. Lazer
    Lazer Road Train Member
    1,850
    2,983
    Jan 22, 2017
    What do have for a motor?
  7. lester
    2,957
    8,087
    Jan 2, 2012
    NW, Iowa
    are you loaded or empty or bobtail?
  8. thatguyfrombk
    52
    34
    Oct 17, 2020
    It’s a Volvo engine with 500hp
  9. thatguyfrombk
    52
    34
    Oct 17, 2020
    I’m empty with a trailer
  10. IH Truck Guy
    4,978
    57,803
    Mar 2, 2008
    Purgatory
    I'm betting once you load the wagon, you'll be under 12 if your 5th wheel is back all the way.
    MACK E-6, Bean Jr., Magoo1968 and 3 others Thank this.
  11. Lazer
    1,850
    2,983
    Jan 22, 2017
    did you spec this truck(order), or did you buy it off the lot?
    Check the placement of the fifth wheel on the frame, it may be attached to far forward.
    Bean Jr. and Grumppy Thank this.
