Overhauled, less power
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Stugots1, Apr 1, 2021.
  1. Stugots1
    Stugots1 Guest
    Hello, got my truck back from an overhaul today. Drove it around the town and it was fine. Had about a 25 min highway drive home. Truck totally floored and I could not exceed 65mph. On inclines, it would slow down to 55 or so. Nothing I could do, even on flat ground would get me above 65. It’s not sputtering or missing. Boost seems good. This wasn’t an issue before the overhaul. I never had the truck floored and I’ve run it well into 80.
    Truck has a Cat c15 in it.
    I don’t know what to make of this.
  3. lester
    2,957
    8,088
    Jan 2, 2012
    NW, Iowa
    Do you have boost gauge or fuel pressure gauge? Bobtail? Take it back
  4. Gix1k
    Gix1k Medium Load Member
    373
    586
    Dec 11, 2019
    I had this issue at one time.
  5. 062
    062 Road Train Member
    6,350
    34,015
    Oct 20, 2013
    Who did the work? If it was cat or a dealership they may have reflashed the ecm.
    91B20H8 Thanks this.
  6. Lazer
    Lazer Road Train Member
    1,850
    2,984
    Jan 22, 2017
    The settings on the computer were probably changed, take it back to the shop. Tell them what you want the limits too be, ie; max mph, idle time, cruise settings, etc. They should have asked you.
  7. AModelCat
    165,197
    Good ol' low NOx file.
    little cat 500, baha and Brettj3876 Thank this.
  8. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    Did shop set overhead correctly? Thats if the shop didn't mess with the ecm like mentioned. Had a mechanical cummins that i had a headgasket replaced. Got it back and it ran like a sick dog. Got the engine overhead readjusted ( valves and injectors) problem solved. I say take it back to the shop or someone better.
