Overhauled or lower miles?
Discussion in 'Freightliner Forum' started by sosa, Jun 9, 2014.
  1. sosa
    sosa Bobtail Member
    20
    Jun 26, 2013
    We are looking to buy a 2007 truck with a Detroit engine. We are confused about whether trying to find one with lower miles or an overhauled one. We do not have much money. We are selling the T2000 KW that just kept going back to the shop and left us in the red. :(
    any opinions please?
  3. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    low miles trumps overhaul any day.
    you never know how the overhaul was done. and you still have the rest of the truck NOT overhauled.
    i've seen lots of bad overhauls. and read about them on this forum.
    Mooose, wore out and sosa Thank this.
  4. Ezrider_48501
    3,845
    5,135
    Apr 2, 2011
    bismarck, nd
    i would say it depends on the budget, id take a recently overhauled truck over one that's showing signs of needing a overhaul soon.
    also depends on overall condition of the truck
    say two trucks identical price one has 1.1million on it overhauled 100k miles ago good samples no blow by well maintained recent suspention rebiuld. clean inside and out new breaks and virgin rubber. the other has 850k blow by low hp on the dino no overhaul, going to need a suspention re-bush some slop in the gear box and a half worn set of caps. id take the 1.1 million mile truck
    sosa Thanks this.
  5. sosa
    sosa Bobtail Member
    20
    Jun 26, 2013
    Our budget is low.. we have seen a truck with a fresh overhaul done at the dealership and they provide warranty.
  6. ShakieHead
    ShakieHead Light Load Member
    73
    16
    Apr 14, 2014
    In a van down by the river
    Only overhauled if it has quality papers that can be verified. Any major shop will have a record of the work. When I bought mine, the best advice I was given was it needed to have one of the major three done. They are a avg of 10g to repair:
    overhauled. Poor boy version can be done for around 10,000
    transmission w/ clutch
    rearends.
    Avoid low mileage fleet or lease maintain. Low miles mean it was broke more than it ran, an once it started to become a money pit for the company that owned it they just threw it away an got another.
    I wouldn't let a high mileage detroit scare ya to much. There are a lot out there that have a million plus an still running great. If you search truckpaper there are pre egr/ accert columbia with 12.7 non egr an 6nz cats for less than 20k a few n14 red tops too. They may not be the prettiest but they make the same money the big fancy trucks do. An if your really tight on money I would stick with the n14 an 12.7 detroits. Cheaper to maintain. 6nz is a beast of a motor but heavy an maintence cost is higher for parts, but easier to find parts for too.
    sosa Thanks this.
  7. ShakieHead
    73
    16
    Apr 14, 2014
    Make sure you read the warranty paperwork. Some are worth about as much as the paper it's on, an some may not be transferable.
    sosa Thanks this.
  8. sosa
    sosa Bobtail Member
    20
    Jun 26, 2013
    Thank you very much!! The dealer that is selling it did the overhaul and they also replaced the turbo. The truck had a blow by and thats why they did the overhaul. It is DOT inspected. I will read the warranty papers. Thank you all for the advice!
  9. just_the
    just_the Light Load Member
    290
    167
    Mar 18, 2014
    Saltillo, MS
    I just got done looking on TP; there are quite a few FLs w/ D 60 12.7, overhauled with papers and other misc. maintenance items, well documented, some w/ warrant, none that will break the bank; take a look.
    sosa Thanks this.
  10. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    Depends on who did work and what's written down.
    For me to consider the claim of overhaul : Done by dealer preferred by mfg shop like Cummins. Original document, no copies. Plenty of time to look at document, no hurry. Discounts taken if head wasn't reworked and supported, old injectors used, radiator not serviced and genuine parts not used.
    For warranty: Terms must be clearly spelled out and all questions answered. If salesman blabs it then it must be on paper or no good.
    Then if all that passes I'll need a couple of hours with truck. Need to see hot and cold oil psi, cold start smoke, hear noises and try everything and see if it works plus bring mechanic with me for on site inspection.
    Finally I need to see title ...not copy but see, hold etc.
    So far so good cept Arrow tossed me out....
    sosa Thanks this.
