Overhead valve adjustment leads to two failed injectors
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Nattyiice, Jun 26, 2020.
  1. Nattyiice
    Nattyiice Bobtail Member
    5
    Jan 31, 2018
    2013 international pro star Maxxforce 13 went in for an overhead valve adjustment At an international dealer, and within an hour Two fuel injectors failed. They claim it has nothing to do with the overhead and we have no way to verify this. It seems extremely unlikely to us that it is just coincidence, any one experience this before? Is this a common thing to happen if you do an adjustment wrong? Any advice?
    Thank you.
    -Chris
  3. AModelCat
    166,495
    I believe those are common rail fuel systems, so nothing in the valve train physically touches the injectors. Unless the tech damaged the injector harness or connections at the injector I'd have to say its a coincidence.
    A5¢, Socal Xpress, pushbroom and 3 others Thank this.
  4. Muddydog79
    Muddydog79 Heavy Load Member
    820
    2,147
    Apr 14, 2016
    Regardless, theres no way to prove anything unless you are there when they pull the cover and know what to look for.
    PE_T Thanks this.
  5. bad-luck
    bad-luck Road Train Member
    3,507
    6,495
    Nov 16, 2013
    Baltimore, Maryland
    The most common injector failures are caused by fuel filtration and contamination. You always get a fuel filter with a lower micron rating.
  6. Heavyd
    Heavyd Road Train Member
    7,839
    6,295
    Feb 4, 2009
    All you can do is ask to see them and check to see if the tops are damaged where the harness connects. Each injector has two little studs sticking up to make the electrical connection. If they are damaged, it is possible something got dropped on to them during the set up.
    A5¢, pushbroom and AModelCat Thank this.
  7. Frontman
    Frontman Light Load Member
    166
    151
    Apr 4, 2012
    I just wouldn't take my truck to a dealer.
