Overweight front axle
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by earnies2, Nov 1, 2019.
  1. earnies2
    earnies2 Medium Load Member
    691
    282
    May 17, 2012
    Dedham, MA.
    I have a 2009 Prostar with a ISX and with fuel I am always 13,400 on front axle. Well yesterday in Tennessee the scale put me OOS. The dot cop said almost every prostar or Volvo are over on there front axle and I had 3 options
    1, slide my 5th wheel
    2, move my load
    3, get load range H tires
    Well 5th wheel all the way back, 23 pallets evenly loaded and tarped 14,440 on weight.
    So I guess I needed to replace my 3 month old steer tires. Called around and 3 miles away was a Goodyear dealer with 2 load range H tires. I dropped the trailer went over the scale and was 13,400 the cop told me either tow it to the tire shop or have them come to you....so they came and put 2 new tires on and I was good to go. But that dosen't solve the problem. How can I increase the weight rating on my front axle. Or remove a fuel tank,my APU, or my headache rack...because the next time I will really be in a jam...
    Feedman Thanks this.
  3. lwlevens
    lwlevens Medium Load Member
    623
    427
    Feb 9, 2018
    Probably adding a few more leafs should do it.
  4. tow614
    tow614 Road Train Member
    3,759
    4,631
    Mar 18, 2013
    Try only fueling 1 tank
  5. bjrc
    bjrc Light Load Member
    81
    97
    Sep 14, 2018
    What does the sticker in the door jamb say on front axle weight?
    Cat sdp Thanks this.
  6. Cat sdp
    Cat sdp . .
    21,319
    76,336
    Apr 8, 2012
    Orion's Belt
    What is your front axle rated for..... 12K or 13,xxxK...?
    daf105paccar Thanks this.
  7. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,081
    Sep 24, 2019
    Raleigh, NC
    I assume you verified the weight bobtail on a cat scale.
    Your real issue is the hulking ISX sitting over the front axle. The headache rack and such are not a factor with steer axle weights.
    Storage boxes near the front, deer guards and APU's mounted by passenger seat will cause issues.
  8. Tx Countryboy
    Tx Countryboy Road Train Member
    1,968
    4,437
    Sep 18, 2019
    Some of the new one are 13,200 rated.
  9. Snoopycda
    Snoopycda Medium Load Member
    361
    715
    Jan 22, 2016
    Edmonton Ab.
    The axle rating and tire's rated weights are what is getting you out of service. The tires rating is on the sidewall, you have two on that axle so double it and that is your maximum weight for that axle. For example, Max Load Single - 2800Kg (6175lb) x 2 = 5600Kg (12,350lb)
    You will need heavier rated tires more than likely, depending on what is legal max weight for your jurisdiction.
  10. Tx Countryboy
    1,968
    4,437
    Sep 18, 2019
    Read his post lol
    starmac and Snoopycda Thank this.
  11. Snoopycda
    361
    715
    Jan 22, 2016
    Edmonton Ab.
    I think I read his post, I was just clarifying it for him.
