Overweight issue
Discussion in 'Experienced Truckers' Advice' started by jjpaez123, Nov 14, 2020.
  1. jjpaez123
    jjpaez123 Bobtail Member
    24
    11
    Dec 26, 2014
    Gm ! every one.
    I got a driver with overweight , im not real familiar with overweight issues : ) would you think this is something can be fixed without removing product ?
    STEER AXLE:11800
    DRIVE AXLE: 33620
    TRAILER AXLE: 35260
    GROSS WEIGHT: 80680
  3. IH Truck Guy
    5,004
    58,159
    Mar 2, 2008
    Purgatory
    No.
    The numbers don't lie.
    Roger McG Thanks this.
  4. FozzyNOK
    FozzyNOK Road Train Member
    2,482
    3,826
    Jul 18, 2007
    Oklahomistan
    The over gross is a problem.. we need to know where the axles are on the rear and where if anywhere they can slide FORWARD.. Sliding 1300 pounds off will take sliding forward around 5-6 "holes". 250 - 300 pounds per "hole". Sliding the fifth wheel forward ONE slot will put a lot of weight forward, but if you have the room to slide the tandems, you can take weight off the front by sliding the tandems further foward The only thing you can do without removing product is removing something like fuel.. also not real possible. Fuel is pretty heavy..
  5. InTooDeep
    4,981
    37,364
    Jan 17, 2016
    Carmichael CA
    Over 80k nope remove 680 lbs
    Roger McG, User666 and Trucker Paul Thank this.
  6. Trucker Paul
    Trucker Paul Medium Load Member
    410
    398
    Aug 15, 2012
    Westland,Mi
    That has to be brought back to shipper if you're gonna pass any scales
    mjd4277, Jenn72 and User666 Thank this.
  7. diamondd817
    diamondd817 Light Load Member
    159
    560
    Oct 11, 2020
    I wouldn't want to move any more weight forward as that steer axle is almost maxed out already. Your real problem is the 680lbs over max. You need to lighten the load by 700lbs. Simple as that.
    NorthEastTrucker and Trucker Paul Thank this.
  8. MACK E-6
    50,128
    239,290
    Pull 700 lbs worth of product off the back and roll with it.
    You’ll be a a few hundred lbs over on the trailer axles, but nobody will kick up a fuss over that.
  9. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Where's the next scale and how much fuel do you have, if you can stand to lose 100 gallons of fuel, also does the truck have a working apu.?
  10. User666
    User666 Medium Load Member
    346
    888
    Sep 22, 2020
    Northeast Ohio
    Take it back to the shipper and bill the customer. Don't risk it. It's not worth it.
    Trucker Paul Thanks this.
  11. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    Are you running through any kingpin states?
    If not. Slide the trailer back. Put weight on drives. Slide 5th wheel forward. Put 13k on steers.
    Hopefully you got full tanks. The fuel will burn off 600 lbs. Off the steers and drives.
    Hopefully you got 13k steers or Hopefully you don't get inspected if you don't have 13 steers.
    If you're running kingpin states. Then take a pallet off the back. Or two.
    I glide 47 Thanks this.
