Overweight on trailer.....unless I violated the bridge law
Discussion in 'Trucker Legal Advice' started by drivingmissdaisy, Dec 16, 2022.
  1. drivingmissdaisy
    drivingmissdaisy Road Train Member
    1,945
    3,318
    Jun 10, 2019
    The other day I picked up a preloaded trailer. I could see on my air gauge in the truck that if this load really did weight 43500lbs, I was probably over on the trailer but I had to go through VA which has a 41' bridge law. I was right at 41'. I figured it would be ok and off I went. I got pulled into a chicken coup in VA and sure enough, he said I was 1700 over on trailer and to pull around back and slide tandems. I did, and rescaled and got the green light and proceeded on, in very obvious violation of the bridge law.
    My question is....which is better to violate on a preloaded trailer? Weight or bridge?
  3. Long FLD
    Long FLD Road Train Member
    13,326
    56,259
    Mar 4, 2015
    41’ to where? Isn’t VA to the center of the tandems and not the rear axle?
  4. Cattleman84
    Cattleman84 Road Train Member
    10,057
    71,983
    Nov 1, 2017
    The Sticks, Idaho
    I never paid ANY attention to KPRA laws... I set my tandems for legal weight and rolled. Was never hassled about it... But I didn't run California.
    Bean Jr., cke, LoneRanger and 10 others Thank this.
  5. Long FLD
    13,326
    56,259
    Mar 4, 2015
    But to answer your question I’d say it depends on how strict they enforce their king pin rule. If the officer is strict about everything then you could end up sitting until the load is reworked and you’re legal on both things. Sounds like you had an officer that kind of didn’t care.
    cke, Rideandrepair, Oxbow and 2 others Thank this.
  6. Professor No-Name
    Professor No-Name Road Train Member
    4,115
    7,924
    Nov 26, 2016
    Not to be rude but i question as to why ya didn't scale it an determine you were over on the trailer axle before crossing a state scale. I always make sure my axles are legal especially if something isn't jiving with load guages that can't always be relied on with our trailers. Our tractor guages are more consistent as far as accuracy. I've never worried about the bridge law except in California.
  7. Jubal Early Times
    3,069
    20,586
    Oct 17, 2022
    King pin ticket is the cheapest ticket. Always choose the cheaper ticket. Only a handful of states even worry about the KPRA.
  8. drivingmissdaisy
    1,945
    3,318
    Jun 10, 2019
    Because as a pre loaded trailer with a steel seal there was nothing I could do about it anyway. I barely had enough time to get the load where it needed to. I picked the load up from our drop yard which was like 200 miles from the shipper. There was no reworking the load. I had to go illegal on one or the other.
  9. Opus
    135,366
    Careful going to Florida......they kinda funny about it......ask me how I know
  10. Jubal Early Times
    3,069
    20,586
    Oct 17, 2022
    It’s only a hundred bucks.
    Rideandrepair Thanks this.
  11. drivingmissdaisy
    1,945
    3,318
    Jun 10, 2019
    I don't know how you interpret this, it's confusing to me. On page 2 it says the rearmost axle OR the center of the two axles.
    https://www.dmv.virginia.gov/webdoc/pdf/dmv109.pdf
    But that's where I had it. As far back as I could put it legally. When I left the scalehouse the tandems were almost all the way back. And they were fine with it.
    Rideandrepair and Long FLD Thank this.
  12. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,472
    Nov 7, 2007
    Possum Booger, Alabama
    Florida is extremely strict about kingpin distance, but they allow 44,000 on the tandems.
    Tennessee also gets a ##### for kingpin every once in a while. I got pulled around back in Manchester one time while pulling my 48' slider with the axle all the way back. FNG comes running out all excited with his rolling tape measure. I was snickering to myself the whole time.
    He gets done measuring and has a puzzled look on his face. Then, with a look of sheepish realization, he says, "Ooohhhh, this is a 48, isn't it?"
    Yep
    Michigan gets a ##### if your kingpin is too long AND too short. Michigan DOT suck. I wouldn't even drive a truck in that state.
    201773 and Rideandrepair Thank this.
  13. Opus
    135,366
    well, using the Busch conversion table, that works out to nearly 5 30 packs........something to consider next time before going rogue
