dear collegies. need urgent help. steer 11480, drive 34490, tandom 33900. 1/25 fuel tractor, almost empty def and reefer. planning to slide fifth wheel to remove weight from drive to steer and keep 1/25 fuel level till i reach customer. cascadia 2018. very long fifth wheel sliding rail. usually one hole is 400-500 lbs. but i cant believe this long rail has so many pounds per hole. anybody know specification for the cascadia 2018 fifth wheel sliding rail? thank you!
Overweight
Discussion in 'Questions From New Drivers' started by igordallastx, Aug 19, 2018.
Page 1 of 4
What position is the 5th wheel at now? Back, center?
Usually it's about 500 pounds per hole.
It sounds pretty much like you're going to be slightly over if you slide them forward 1 hole. Try it and get a $1.00 re-weigh. I would probably take my chances being slightly over at a D.O.T. scale and hope they don't nitpick. Whatever you do don't put on more fuel!
igordallastx Thanks this. -
I think fifth wheel is about 250 a hole
Punisher255, bigblue19 and igordallastx Thank this. -
totally there is 19 holes. now 5th wheel placed at six hole from the tractor side.
Hopefully you're at a truck stop still. Move it up one hole and try a re-weigh. If my estimate of 500 pounds per hold is correct you should be pretty close. You know how to slide the fifth wheel with a loaded trailer, right?igordallastx Thanks this.
Sure, thank you. I drive before old manual FT and there one hole was close to 500 pounds. But sliding rail was about ten holes. This one has 19 holes. Probably Highweyghman is right - 250 lbs. But yes, will reweight tomorrow. Driving now from pump to pump with empty tanks. But there no chance - or roll, or wait till Monday to remove some palletes from the back.
Good luck
Yep, 1 hole is all I would do. Better to be a little over on the drives then the steers & as long as your under gross even California wouldn't sweat a couple hundred.
Page 1 of 4
