Owner Operator, I need work for a single axle daycab. Any ideas?
Discussion in 'Experienced Truckers' Advice' started by lmccoy17, Jul 12, 2018.
  1. lmccoy17
    lmccoy17 Bobtail Member
    5
    Owner Operator, I need work for a single axle day-cab. Dallas, TX. Any ideas?
  3. GreenPete359
    GreenPete359 Road Train Member
    2,264
    5,450
    Oct 21, 2017
    Driving my recliner
    Hot shot frieght. Lease to fed wrex, haul hot air
  4. Pull sand or gravel
    Pull hay
    Pull grain
    lmccoy17 Thanks this.
  5. lmccoy17
    5
    I am at my whits end for work for this puppy truck. I am buying a sleeper soon. however, If I can use this puppy truck I would like too. I tried FEDEX, can not get anyone to give me information. I have even talked to supervisors there. They are zipped mouth. What is Hot air? or is that a joke? I am doing research on Hot shot freight. remember this is a DAY CAB. Over night is a nightmare. and Deadheading back is a zero sum game.
  6. lmccoy17
    5
    I will look into Sand and gravel. Now, this is a single axle day cab. max load is 20K Lbs. It is a puppy truck. however, I will see if I can work any part of these markets. I never thought of these markets . Thanks.
  7. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    Anything sand,gravel will require your truck to haul a minimum of 23 tons. Nobody will ever hire a truck with low weight capacity like that. I work in this type of industry. You will need your own trailer as well. You need 18 wheels but there is a lot of money in it if you live in the right area.
  8. Oldironfan
    Oldironfan Road Train Member
    5,776
    5,544
    May 22, 2017
    UPS, FedEx?
  9. Buckeye 60
    Buckeye 60 Road Train Member
    1,229
    1,269
    Apr 19, 2018
    you can't haul the heavy stuff with a single axel FedEx will not hire you direct you probably can hook up with one of there contractors try local frieght agents also they might have a lot of stuff they need ..... plenty of Texas loads coming out of Dallas
  10. 07shaker
    07shaker Light Load Member
    200
    727
    Jan 12, 2013
    Tx
    Get set up to haul portable storage sheds. It's a huge market and your single axle would work great. You'd need to be able and willing to invest a lot in equipment. It's also hard work but pays well if you're not scared to work.
