Paccar APU AC connection question.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Deezl Smoke, Jul 25, 2022.
  1. Deezl Smoke
    Deezl Smoke Medium Load Member
    539
    356
    Feb 12, 2011
    Hillsboro Oregon
    2021 Peterbilt 567 has the "smart air" system. I need to vacuum then recharge, but both lines have the large manifold connectors. (see attached pictures)
    As mentioned in a few prior threads I found, dealer has no clue. Only info I could get was the 134 capacity.
    So how do I vacuum this system? Just pull vac on the low side using the high side connector? Or?... ac fittings 1.jpg ac fittings 2.jpg
  3. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    You can recover and recharge thru one port.
    charge amount is 1.156 lbs.
    krupa530 and Deezl Smoke Thank this.
  4. pumpkinishere
    pumpkinishere Heavy Load Member
    945
    4,986
    Apr 21, 2021
    This place in Columbus Ohio is great with apus. We have a comfort pro and we were having issues and this old guy was great. ELW Columbus ohion 504A4784-982B-4065-8506-BE1203EA7E1C.png
    Deezl Smoke Thanks this.
  5. Deezl Smoke
    539
    356
    Feb 12, 2011
    Hillsboro Oregon
    Awesome news, Thank you very much for that.
    krupa530, Goodysnap and pumpkinishere Thank this.
  6. ServiceTech
    ServiceTech Bobtail Member
    4
    I'm glad I'm not the only that noticed this issue. Now to add to this, the manual (which really sucks) says not to add oil, as well as the sticker on the unit itself. Now I'm finding out that the oil that is needed is a PEV oil and that the two cannot be mixed. BUT, nowhere can I find out how much oil to use. I only have one AC recovery machine here and it has always had PAG oil. So it looks like I need a separate machine to do these smartair systems. Am I correct in all of this?
  7. Deezl Smoke
    539
    356
    Feb 12, 2011
    Hillsboro Oregon
    I don't know about the oil. It says not to add any, so I did not.
    On the recovery system, do you have the ability to pump refrigerant into the system? The pressure of the canister, 30lb or 12oz can no matter, it will not fill the system. You have to pump the 134a into it.
    If you look at the system it will say "Bergstrom Inc" I called them and they answered the phone. Ya,...no kidding right. They answered my questions very promptly and professionally. Give them a call, hopefully you will have the same great luck as I did.
    ServiceTech Thanks this.
  8. ServiceTech
    4
    I heard of Bergstrom, I didn't realize that they are the manufacturer of the smartair
  9. Deezl Smoke
    539
    356
    Feb 12, 2011
    Hillsboro Oregon
    This is what is on the interior, under the bunk.
  10. Bigsnow
    Bigsnow Bobtail Member
    You must vacuum the system to charge the lines. The refrigerant is not "pumped in."
