paccar excessive coolant pressure
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by krazzyboi_44, May 30, 2025.
  1. krazzyboi_44
    krazzyboi_44 Light Load Member
    298
    42
    Apr 30, 2008
    BAton Rouge,Louisiana
    My coolant system just started having excessive pressure. After doing a little research i see the compressor head is a common problem. How can i test the compressor a see if thats the problem or not?
  3. LongHaulTrailer
    LongHaulTrailer Bobtail Member
    25
    29
    Jul 4, 2024
    Saraland, Alabama
    Back feeding the discharge line from where it connects to the dryer is one of the ways. You disconnect the line (biggest one) and use an adapter to hook it up to shop air. When you do that, you'll get pressure in the surge tank. If you have a cooling system pressure tester, you hook that to the fill cap for the tank and let the shop air run for a few minutes. When you open the valve on the tester, you'll hear air coming out.
    Another way that sometimes works is on a cold engine, remove the coolant fill cap to make sure there's no pressure, replace the cap, and start the truck. It'll pretty much immediately start to pressurize the tank. That's normally a good indicator as long as your coolant looks normal and not dark or oily. If that's the case, you'll have to do a combustion gas test.
    Replacing the compressor head isn't difficult but doing it the right way requires a torque wrench and I always recommend replacing the 2 coolant lines since you're right there and they're prone to breaking. I haven't had a customer deny them yet.
  4. beastr123
    beastr123 Road Train Member
    2,952
    24,211
    Jan 2, 2014
    Moose Jaw SK CAN
    You can also disconnect the coolant lines and cover the compressor connections with deflated balloons.
    Connect shop air direct to the output side and roll the engine over.
    If the balloons inflate that is your reason for pressurized cooling system.
    BoxCarKidd, D.Tibbitt and AModelCat Thank this.
  5. FLHT
    FLHT Road Train Member
    1,429
    2,546
    Aug 2, 2014
    What motor ?
    MX13 is famous for dropping a liner ....
  6. AModelCat
    164,835
    Putting that one away in the brain compartment for future use.
    beastr123 Thanks this.
  7. beastr123
    2,952
    24,211
    Jan 2, 2014
    Moose Jaw SK CAN
    third generation knowledge... Thanks Dad
    BoxCarKidd and AModelCat Thank this.
