Paccar for owner operators?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by John from Oregon, Sep 9, 2020.
  1. John from Oregon
    John from Oregon Bobtail Member
    11
    Jan 20, 2019
    It seems as though owner operators go for Cummins over Paccar. New Kenworths and Peterbilts have mostly Paccar engines now. Are Paccar engines that more expensive to maintain compared to Cummins?
    Thanks in advance for your reply.
    bzinger and spsauerland Thank this.
  3. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,382
    Jul 16, 2012
    Bentonville Arkansas
    Cummins is easier for owner operator to work on as all the manuals are online and anyone can work on them. Paccar pretty much stuck with dealer.
  4. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
  5. Long FLD
    Long FLD Road Train Member
    12,932
    54,265
    Mar 4, 2015
    If you’re looking at a Paccar from 2016 on or so you will have way better luck than the earlier ones. They’ve changed the egr and fuel system, basically the new ones share a block with the early ones and that’s about it.
    Mine is 510/1850 and I’ve been pretty happy with it. I’ve had to replace a few sensors, the exhaust manifold, and water pump. The exhaust manifold is a 3 piece and the gaskets at the slip joints will start leaking. You can just replace the gaskets but you’re already pulling the egr off anyway so I felt it made more sense to just replace the manifold at that point. I’m at just over 463k on mine now.
    The hardest part for me was learning to drive it at a lower rpm. The torque curve is between 1000-1400 rpm or so. I try and stay between 11 and 1400 as much as I can. I have lo 22’s and 3.36 rears so I do end up around 1500 or a little over if I have to be in a hurry.
    I think it’s a crap shoot with any of these new engines. You can get a good one or a bad one from anyone. I know guys who are happy with the X15 and I know guys like my brother who had to delete them to get them to run right. And I know guys like me who have had good luck with the MX13 and I know guys who’ve gotten bad ones. A friend of mine ordered 5 389’s last year all spec’d the same with MX13’s and 4 run great and one is in and out of the shop.
    I’m in the boat right now of deciding what I want to do next year and I’m really thinking about a Freightlinet 122SD with a Detroit. The Detroit seems to be the most trouble free of the new engines anymore.
    TruckingSam, bzinger, Edjahman and 6 others Thank this.
  6. 650cat425
    650cat425 Road Train Member
    1,548
    11,043
    Jan 26, 2020
    Pennsyltucky
    If you're trading in the pete, how about a heads up? :D
  7. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    How heavy does he run at?
    Gross weight.
    650cat425 Thanks this.
  8. Long FLD
    12,932
    54,265
    Mar 4, 2015
    I’d say 85-90k gross usually.
    650cat425 and daf105paccar Thank this.
  9. Edjahman
    Edjahman Medium Load Member
    648
    444
    Apr 2, 2013
    I like my mx13 EPA 13. It has 520K currently.
    bzinger Thanks this.
  10. GYPSY65
    GYPSY65 Road Train Member
    1,957
    5,266
    Nov 16, 2012
    SW FLA
    I’m on my 3rd MX and have no real complaints
    2014 KW and 2019 Peterbilt and low a 2021 Peterbilt all with 510hp
    My ‘14 ran fine but was going through sensors until KW in Ogden Utah had it in
    They were the first shop to recommend flushing the egr cooler
    They said they have guys who every year just flush the cooler and burn the def filter and those guys never have issues
    runningman0661 Thanks this.
  11. Edjahman
    648
    444
    Apr 2, 2013
    My MX13 EPA 13 is at 600K and if you pay attention to it and do the maintenance, it's fie.
    I'm probably one of the few people who actually like it.
    I've owned ISX and X15 and I swore I'd never own a Cummins again.
    It's just my experience. You have to read up on different systems and learn how they work and maintain them.
    I'm sure it's the same for any engine.
    You have to care and not just run run run it.
    spsauerland and jason6541 Thank this.
  12. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    I liked my MX13’s I owned they are a million mile engine. Just follow maintenance recommendations and read the engine manual. Cummins is so much more expensive and really not that reliable.
