Paccar MX-13 EPA 13 RANDOM CODE SPN 1231 FMI 2
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by rshakin, Jul 1, 2019.
  1. rshakin
    rshakin Bobtail Member
    20
    Hello guys,
    Just picked up a truck Peterbuilt 389 with Paccar MX-13 EPA 13 Engine.
    Anyone ran across this code
    Hardware or software fault on CAN2 bus U1011 1231 2 M1 + R1 n Comprehensive
    This was pulled with DPA5 Adaptor with their built in house software.
    Symptom: Truck was in a pull going up 6% grade 80 ambient temp, truck flashed stop engine immediately red code, check came on and stayed lit, warning went away 1.5 seconds later. Filters were just pulled and cleaned about 4 days ago, 1.6 was the reading before the cleaning 1.1 after cleaning. Any ideas ?
    DPF Cleaned
    DEF Filter Replaced
    OIl Change done all Paccar filters
    Overhead ran to Paccar EPA13 Spec
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,887
    May 31, 2010
    West Harrison, In
    Have ran across the code multiple times and have a Pete just starting to throw it once every couple days. I have replaced VGT actuator, BPV actuator, and repaired pins in harness for BPV and EGR valve to repair this fault on other units, so need to do meticulous troubleshooting because all the parts are pricey. Here is a troubleshooting guide that helps isolate the problem. Make darn sure you have good power and ground before condemning any part.
    QUALITYTRUCK, pushbroom and Goodysnap Thank this.
  4. pushbroom
    pushbroom Road Train Member
    1,779
    7,313
    Sep 1, 2012
    That code can be a real #####. Check the mega fuse on the rh side of the batt box. Give the cables a 10 pound pull test as the rear likes to corrode off. Turbo actuator wiring pigtail can sometimes get rubbed as well. After that its alot more indepth and more technical troubleshooting following the document @spsauerland posted.
    QUALITYTRUCK and spsauerland Thank this.
  5. Hebrew Hammer
    Hebrew Hammer Bobtail Member
    10
    I was wondering if you had any update in this issue. Had the same thing happen to me yesterday.
