Paccar MX 13, makes weird noises.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Just.Do.It, Nov 3, 2019.
  1. Just.Do.It
    Just.Do.It Light Load Member
    55
    37
    Jul 23, 2018
    Tampa FL
    Hello everyone! Title says it all, squealing noise coming from the engine when I use engine brake. Started around 3 months ago, getting worse. Peterbilt dealrship mechanics could not find anything. Link to youtube video is here -
  3. Goodysnap
    Goodysnap Road Train Member
    3,791
    9,228
    Jul 12, 2017
    I could not hear the specific noise from your video. You likely have an exhaust leak. Have the intake and exhaust system pressure tested or smoke tested to identify the leak.
    magoo68, pushbroom and Just.Do.It Thank this.
  4. FdEF
    FdEF Light Load Member
    70
    57
    Dec 5, 2017
    Ogden, Ut
    Check the back pressure valve. Seem to be a common problem on EPA13
    Just.Do.It Thanks this.
  5. Just.Do.It
    55
    37
    Jul 23, 2018
    Tampa FL
    How do I check that thing? It moves a little while idling. Not sure what else it should do, and shouldn't do.
  6. FdEF
    70
    57
    Dec 5, 2017
    Ogden, Ut
    bump your rpms up with the cruise. as soon as your fan kicks on it will move that back pressure valve and it will either stop making the noise or make it worse if its the BPV
  7. Just.Do.It
    55
    37
    Jul 23, 2018
    Tampa FL
    Thank you, will do that
  8. Rounded_nut
    Rounded_nut Light Load Member
    92
    107
    Feb 25, 2018
    Check for soot around the slip joints on the exhaust manifold as they leak, also egr valve and all the gaskets.
    spsauerland and Just.Do.It Thank this.
