Paccar MX low oil pressure problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Pablo-UA, Sep 7, 2015.
  1. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Got 2010 truck in workshop.
    At idle oil pressure is less a 0.8 BAR. When engine revs to 1000 rpm it is about 1500 ore more BAR.
    At max RPM all is OK - 4-5 BAR.
    Looks like internal oil leak. Does anyone had this problem before?
  3. AModelCat
    164,643
    Max RPM oil pressure is ok but it's low at idle? Did you get those pressure readings from the dash gauge or from a test gauge?
  4. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I used data from OBD connector too.
    ESA reads the same
  5. AModelCat
    164,643
    I would start with plumbing a good test gauge into the engine to see if the oil pressure is truly off, or if it's an oil pressure sensor that isn't reading properly.
  6. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    i tried to swap oil pressure and fuel pressure sensors (the same part #) and other sensor reads the same pressure
  7. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    This is oilsystem description.... From Holland.
    This engine is not so simple as it looks
  8. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    Number 18 or complete oil pump..
  9. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    May be, but oil pump is the most lubricated part in engine.
    So I wanna check oil pressure regulator and geartrain
  10. asavage1576
    asavage1576 Light Load Member
    62
    36
    Mar 18, 2013
    Dallas,Tx
    Check history and see if an oil change was done recently. We had one acting similar and the PM guy had left little bushing out of centrifugal filter
  11. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I removerd centrifugal filter, cleaned all filter unit with solvent, changed oil and start engine!
    over 70 PSI on laptop! Ok, I tried mechanical gauge - the same figures.
    I did test ride, but I cant warm up bobtail truck, so in monday I gonna find heavy trailer for test
