Pain at the Pump
Discussion in 'Ask An Owner Operator' started by Ryroco, Aug 16, 2022.
  1. Ryroco
    Ryroco Bobtail Member
    Aug 15, 2022
    How much time should someone “reasonably” take at the pump - in minutes.
  3. DRTDEVL
    DRTDEVL Road Train Member
    1,705
    3,428
    Jan 27, 2013
    Austin, MN
    Depends on several factors, most notably the size of the tank and the rate of flow.
    If the pump is slow and someone is taking on 250+ gallons, they could very well be there 30-45 minutes.
  4. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    In minutes is an irreverent metric. It takes as long as it takes.
    Fuel tanks, add def, pull forward and fuel reefer is obviously going to take more time than a day cab that tosses in 50 gallons at the end of the shift.
    Both are fine to take as long as needed to fuel. Both need to move forward after that. Doesn't matter if it takes the day cab guy 6 minutes and the reefer guy 20.
  5. Siinman
    Siinman Road Train Member
    5,535
    14,240
    Mar 5, 2017
    Kansas City, MO.
    I’m normally a 15-18 minutes to fill and clean windows.
  6. Big Road Skateboard
    7,209
    40,984
    May 2, 2021
    Fill up, order food, logs, a bit of social media, and dinner. Roughly an hour if i don't shower
  7. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Less than 15 minutes throwing in 200 gallons and washing the windows
  8. Opus
    132,804
    Honestly, I can usually get in and out in less than 10 minutes. 5 minutes if I'm only filling one side and no DEF
  9. TallJoe
    TallJoe Road Train Member
    7,490
    16,273
    Apr 12, 2016
    Chicagoland
    Some poeple must walk over to the fuel desk to activate the pump. Some are slower than others. There can be a line at the fuel desk or a technical problem with the fuel card. Some will check and add fluids or add tire pressure. It all depends on circumstances.
    I'd say that 30 minutes is too long no matter what if someone is waiting behind you.
    On the other hand, If the guy behind has an opportunity to safely back up and move into another vacant fuel pump bay then they should do it.
  10. DRTDEVL
    1,705
    3,428
    Jan 27, 2013
    Austin, MN
    Say you pull in and want to load up on 200 gallons, but the pump is only putting out 10 gpm. You also need to put in 40 gallons of reefer fuel and 15 gallons of DEF.
    After 15 minutes, the truck is full, then you put in DEF. Another 3 minutes and you're getting in and pulling up (3 minutes) to set up and fill the reefer. 4 more minutes pass, and the receipt printer is broken. You then pull up, go inside to get the receipt, only to find yourself waiting in line for 5 minutes. Now you run to the john, drain the main vein, and head back out to the truck. You just spent 25 minutes at the pump and another 10 minutes inside, and you didn't even get anything to drink, but were parked there at/in front of the fuel island for 35 minutes.
  11. bad-luck
    bad-luck Road Train Member
    3,450
    6,362
    Nov 16, 2013
    Baltimore, Maryland
    It really depends on how long the flip flop wearing driver in front of you takes to to wash their feet in windshield washing bucket, and eat their dinner at the fuel island....
