Palletized Equipment
Discussion in 'Flatbed Trucking Forum' started by cgilliland, May 15, 2020.
  1. cgilliland
    cgilliland Medium Load Member
    321
    744
    Mar 13, 2017
    what do you guys use to thread straps through back to back pallet bases across the deck
  3. SmallPackage
    5,805
    18,594
    Dec 20, 2019
    Marion Texas
    I have used a homemade 4ft long 1/2 rebar with a welded on t-handle on one end and a barbed hook on the other. It will grab and push and pull chains and straps were you can’t get an arm or hand. Also good for the fithwheel release handle too.
    cke, JonJon78, Kyle G. and 3 others Thank this.
  4. TripleSix
    133,434
    Paint roller on a broom handle.
    stwik, cke, JonJon78 and 3 others Thank this.
  5. SmallPackage
    5,805
    18,594
    Dec 20, 2019
    Marion Texas
    I like that idea. I can see that also being a help if you need to wrap up some rope or twine in a hard to get at area. Tie it on one of the wires on the roller and then pull or push it.
    TripleSix and cgilliland Thank this.
  6. chriskc
    chriskc Light Load Member
    173
    366
    Mar 31, 2013
    Kansas City mo
    Fifth wheel puller bar.
    cgilliland Thanks this.
  7. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    I have a piece of green plastic coated wire I picked up at a John Deere facility. It's heavy duty enough to pull chains or straps, yet flexible enough to coil up and tuck in the sidebox.
    cgilliland and kylefitzy Thank this.
  8. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    I used to carry a paint roller and handle to push/pull chain or strap, I also had a bent piece of rebar, or at another time a small diameter piece of galvanized conduit pipe that I used for pushing straps through spaces too narrow for the thicker paint roller.
    TripleSix, cgilliland and Kyle G. Thank this.
  9. Kyle G.
    Kyle G. Road Train Member
    3,902
    20,577
    Jan 23, 2016
    Eastern Iowa
    I use a pole made out of some 1/2 inch diameter metal conduit. I drilled a hole through it on one end and looped some wire through that. So it kinda resembles one of those dog catcher snares used by animal control.
    And I got two 5-ft sections that screw together, to make it easier to stow.
  10. FoolsErrand
    FoolsErrand Road Train Member
    2,877
    12,169
    Sep 15, 2017
    I made a 4ft conduit handle with a sched40 pipe coupler welded to the end. Anything i welded a sch40 male nipple to became a tool insert for the conduit extension. Mostly i used a piece of 3/8 rod with a few inches of 90* bent end on it. Was in a junkpile.. Some kinda machine part. Just a long "L"
    It was handy that i could choose between 4 and 8ft tools without having to store an 8fter.
