"pancake"
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Freebird135, Jun 24, 2010.
  1. Freebird135
    Freebird135 Road Train Member
    1,527
    906
    May 7, 2009
    In the air conditioning
    prolly a stupid question, i never heard this term but i overheard it the other day and was wondering what it was
    its a truck part, any ideas:biggrin_25521:
  3. Kittyfoot
    Kittyfoot Crusty Ancient
    2,092
    3,056
    Sep 21, 2009
    Sorrento, Louisiana
    That's the "truck part" the newbie driver installs the first time his rig leans waaaay over or his trailer tries to come around on him.:biggrin_25522:
  4. walleye
    walleye Road Train Member
    3,028
    4,306
    Aug 21, 2007
    Land of Cheese
    Sometimes the diaphragm in the brake chamber is referred to as a "pancake",...
    When you see on yous will know why,....
    jtrnr1951 Thanks this.
  5. Heavyd
    Heavyd Road Train Member
    7,833
    6,285
    Feb 4, 2009
    Yah, that is where I have heard this too. Seems to be a popular term in Quebec.
  6. Allow Me.
    10,794
    12,694
    May 28, 2009
    Rancho Mirage, Ca.
    Well, my ex's handle was "Pancake", and I once heard a driver over the CB radio saying he was going to "pancake" a doo-doo onto his seat unless he didn't hurry into the truck stop real quick. But, other than loving pancakes with REAL butter and maple syrup, I've never heard the phrase before pertaining to a truck part.
  7. heyns57
    heyns57 Road Train Member
    2,209
    1,011
    Dec 30, 2006
    near Kalamazoo Speedway
    Brake air pressure expands the pancake-size rubber diaphragm to move the brake push rod. A blown pancake will usually have a small slit allowing applied air pressure to leak. This can be detected by a slow drop in air pressure with the engine off and the brakes applied. If an air leak can not be found at the various hoses, listen at each brake chamber.
  8. heavyhaulerss
    3,723
    2,041
    Dec 23, 2009
    AL/TN BORDER
    pancake is a rubber diaphram that is is some types of brake chambers. NOT the 3030 type. they cannot, should not be opened up. the other type when leaking, instead of replacing the whole thing, you can replace pancake inside while on truck. real cheap. I have 2 spare's alway's with me. in any truck store you'll see them. look's like a small rubber pie plate.
  9. josh.c
    josh.c Road Train Member
    1,105
    420
    Feb 22, 2009
    Knoxville, Tn
    It's completely safe to replace the pancake on a 3030 IF you cage the spring. Much faster (and cheaper) than replacing the whole chamber.
  10. 07-379Pete
    07-379Pete Crusty Commando-Pete
    2,549
    2,347
    Oct 3, 2008
    Campbellsville, Ky
    Most new brand 3030 brake chambers are now clamped shut on the front chamber where that ###### spring is,you cant get into it unless you cut the clamp, dont ### with that spring or you might loose a hand or something worse when that thing comes apart, the back half is the one where you can change the "pancake" if it goes bad.
    Peterbilt of Lousvills has 3030 brake chamber for $49.
    josh.c Thanks this.
  11. heavyhaulerss
    3,723
    2,041
    Dec 23, 2009
    AL/TN BORDER
    that is very dangerous. it says so on the brake chamber.
