Parking brake causing noise
Discussion in 'CB Radio Forum' started by Swift09, Aug 29, 2020.
  1. Swift09
    Swift09 Light Load Member
    77
    106
    Jul 4, 2019
    Why when I release the parking brake on the truck do I get an increase of static? Truck is a 2001 387
  3. AModelCat
    164,770
    LED/aftermarket running lights?
    My LED light bar screws with my FM radio reception, can't see why it couldn't mess with the CB too.
  4. Ridgeline
    22,726
    123,424
    Does the noise go away if you apply the brakes?
  5. Swift09
    77
    106
    Jul 4, 2019
    No, not the service brakes with the pedal. Just parking brake. I didn't know there was any electronics tied in with the parking brake? I had the valves out a couple months ago I thought it was just valves?
  6. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    In many trucks static disappears when you apply foot brakes...Wheel brg static,apply some graphite powder in wheel brg oil..Poof gone..
  7. Ridgeline
    22,726
    123,424
    Should not be anything that causes static in a 2001, abs module maybe if it has one. The only other thing I can think of is if it has a body computer and thats starting to freak out with age. The other thing is how old is the coax itself?
  8. craig_sez
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    True..Didnt notice yr of the truck..
  9. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    Only thing I can think of is it be a truck that goes to Canada and has day time running lights that come on when the brakes are released.
    AModelCat Thanks this.
  10. AModelCat
    164,770
    Pretty much what I was thinking lol. Especially if the headlights were swapped out to LED/HID at some point.
  11. craig_sez
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Usually the dtr are the signals vs the actual headlights..
    Being a 2001 it would have to be an aftermarket add on..
    Unplug them all or pull the fuse and see..
