Part #
Discussion in 'Ask An Owner Operator' started by Ikamob01, Oct 8, 2022.
  1. Ikamob01
    Ikamob01 Medium Load Member
    314
    195
    Dec 4, 2021
    Guys looking at the part below, can you identify the part #? 20221008_182835 (1).jpg
  3. JonJon78
    JonJon78 Road Train Member
    7,242
    43,050
    Jul 1, 2018
  4. Ikamob01
    314
    195
    Dec 4, 2021
    So whatsup with the K058447? Its also written at the bottom/
    Rideandrepair and JonJon78 Thank this.
  5. JonJon78
    7,242
    43,050
    Jul 1, 2018
    Good question. Maybe one of the mechanics has the answer. Not sure myself why lots of parts have several numbers... @Goodysnap @AModelCat
    Rideandrepair and Ikamob01 Thank this.
  6. Long FLD
    Long FLD Road Train Member
    12,925
    54,243
    Mar 4, 2015
    Could it be a more common part that can be programmed differently depending on the application? When you Google the k058447 there’s a lot of links with info and such, when you Google k065144 some of the links have it listed as a “genuine International” part.
  7. Ikamob01
    314
    195
    Dec 4, 2021
    Very confusing!
    Rideandrepair Thanks this.
  8. Goodysnap
    Goodysnap Road Train Member
    3,774
    9,202
    Jul 12, 2017
    Why do you need to know the part number? Bendix modules are programmed VIN specific. You will need to order thru IH and it will come preprogrammed to your VIN. If your thinking used, save your money.
    Rideandrepair, Vampire and Long FLD Thank this.
  9. Long FLD
    12,925
    54,243
    Mar 4, 2015
    I’d be inclined to lean toward the k065144 because that’s what the sticker lists as the Bendix part number. And that number appears twice on the sticker at the top. Plus Google shows it coming up as an International part. International could have some type of programming from Bendix to make it talk to their other computers or something.
  10. Long FLD
    12,925
    54,243
    Mar 4, 2015
    That would explain why a new one is $2600 and a used one on eBay is less than $200. Lol
  11. Ikamob01
    314
    195
    Dec 4, 2021
    Not true. I went to international and they approved use ones . Will check it out tomorrow. I don't this that part is for international prostar 2015. Just my opinion.
  12. Ridgeline
    22,744
    123,707
    OF course they approve a used module, they have no choice but ... the problem is they won't guarantee the work because of it being used/referb/equipment pull not through them.
    This quote is the best explanation - read it carefully ...
    Also this is a ABS/traction control module or ECU, it needs to be very specific to your truck.
    wis bang and Goodysnap Thank this.
