Partial placards ?
Discussion in 'Experienced Truckers' Advice' started by localintermodalsni, May 16, 2021.
  1. localintermodalsni
    localintermodalsni Bobtail Member
    10
    12
    May 16, 2021
    If 1/4 of the placard remains from the previous load, isn't this some kind of ticket if you don't remove it ? My company was trying to tell me that if you couldn't see the numbers it's not a big deal. I refused the load due to mine and their uncertainty.
    One guy was telling me to tape it, the other to spray paint it, and the other to run it. However if I were to get a ticket, they'd tell me it was my ticket. I know it's probably "unlikely" to get a ticket for such a thing, however if it's illegal I'd rather not gamble. DOT sits outside of the railyards all the time, I've been pulled over numerous times, but this partial placard thing is a new one to me, normally if the rail mechanic is in the area I have him scrape them off.
    I was always under the impression all previous hazmat placards in their entirety had to be removed when the hazmat load was off of the trailer. Maybe i'm mistaken though.
    slow.rider Thanks this.
  3. MACK E-6
    50,089
    238,946
    I personally would remove it.
  4. localintermodalsni
    10
    12
    May 16, 2021
    Can't climb on anything to remove it though. on containers the placards are way up there, so it can be seen even when it's in the well of a rail car.
    tscottme Thanks this.
  5. MACK E-6
    50,089
    238,946
    How about unhooking the trailer and parking near the stickers?
    It may not even be an issue, I don't know. But my OCD would demand it.
  6. buzzarddriver
    3,833
    11,599
    Feb 1, 2011
    Dallas, TX
    Today's driver: Look for a reason not to work vs look for a solution.
  7. localintermodalsni
    10
    12
    May 16, 2021
    Should've thought better than to ask other drivers my bad
  8. JoeyJunk
    JoeyJunk Road Train Member
    8,762
    68,032
    Dec 31, 2010
    Washington, PA
    I’d do whatever I could to be able to reach it. I’m the same way with OCD. Most guys at my company can reach them and just cover the remaining with duct tape. They won’t use the placard holders.
    Helpful hint. If you dont have tape or plastic sheets to hold placards in holders, you can jam a little sliver of a pallet in along an edge and it will hold well.
    CrappieJunkie and slow.rider Thank this.
  9. slow.rider
    slow.rider Road Train Member
    2,005
    4,741
    Apr 4, 2017
    NYC
    It is a violation, but maybe less likely to attract scrutiny with no numbers showing. I'd likely have accepted it and informed your company there might be a delay while you figure it out. Maybe drive to the first TA/Petro, step into the shop and ask to borrow their ladder. If you're stopped on the way, inform the officer up front of your awareness and intention. Or maybe the railyard's chassis repair corner has a ladder you or they can use. Or maybe lay some duct tape on a broom and reach up there with it.
  10. Dennixx
    Dennixx Road Train Member
    4,548
    14,627
    Feb 13, 2010
    twin cities
    There ya go OP.
    Analytical thinking and it's not even his problem
  11. Arctic_fox
    4,529
    25,628
    Sep 16, 2016
    Had something like this a few years back. Had half a flamable placcard on a tanker we had cleaned out to move fresh water in an aquard place i couldn't reach without a ladder. So i dropped the trailer and bobbed to the home depot about 15 mins down the road and got one of those bug sprayer extensions you stick on a pole like this one https://www.homedepot.com/p/DocaPol...ns-Pole-Not-Included-DP-TreeSprayer/314616562 and a can of white spray paint. Stuck it onto the end of my dipstick and used it to paint over the placcard remains.
    Sometimes a little problem solveing goes a long way to getting a load.
    Numb, Hammer166, Dennixx and 1 other person Thank this.
