Partial pretrip inspection CDL test
Discussion in 'Questions From New Drivers' started by Shaner.STL, Jan 23, 2019.
  1. Shaner.STL
    Shaner.STL Light Load Member
    63
    26
    Jul 26, 2017
    Hi, taking my CDL at the end of the week most likely. When we go over it we do a full pretrip almost everytime. I know the testing center can ask you to do a partial inspection of certain areas of the truck or trailer so I’d like to get some clarification on what those all include.
    If they ask for me to inspect the engine compartment what exactly does that include? Do I need to go into the steering components, power steering fluid, the suspension components, etc?
    Same w the front (steer) axle. Do I need to mention the steering components along w the suspension, brakes, rim and tires?
    For the rear (drive) axle I know to list suspension, brakes, rims and tires but do I also include the pumpkin, torsion bar, and 2 black air bags that are on our tractors.
    Any help would be appreciated. Thanks!
  3. mindes
    mindes Medium Load Member
    626
    540
    Feb 17, 2015
    Crestview, Fl
    If they say pretrip under the hood, do everything that you would check that's under the hood on a pretrip. Hoses, belts, brakes, leaks, tires, etc. Too much is better than not enough.
    If the school is testing you, ask them for clarification.
  4. Ridgeline
    22,732
    123,558
    DO you have a cdl manual?
    If so it is in the manual.
    BUT ....
    You may be asked for the following -
    if the fan belt is in good condition or with cracks and what constitutes a bad belt
    If the springs have any cracks or any defects that you can see.
    You shouldn't be asked to do this but you may be asked to describe how to test for loose steering components, including free play. They may also ask you how to test the steering for free play in the steering column either while you are inside or outside the truck.
    You will also be asked where different items are like coolant tank, dip stick, shocks and other items are.
    You will also be asked what the wear limit is for the steers - this one seems to trip up everyone.
    Again there isn't much they will ask you about the read, but they will ask you what the wear limits are on the drive tires, they are different than the steers.
    Everything they ask is in the book.
  5. Kyle G.
    Kyle G. Road Train Member
    3,902
    20,578
    Jan 23, 2016
    Eastern Iowa
    You will need to plan on checking everything listed in your manual. Yes, many times the examiner will stop you halfway through and say that’s good enough. But that seems to be at their discretion so it’s hard to say what will happen for you when you go to test.
    The more thorough you are right from the start, the more likely they will let you skip over things.
  6. drumchaos
    drumchaos Light Load Member
    188
    148
    Dec 23, 2018
    Nashville, TN
    I’m not sure if this is correct or not, but while watching a pretrip video, the guy said that you can usually get away with saying, I would do the same on the other side, if it is a component that is on both sides of the vehicle.
    Anyone know for sure?
  7. BIGLEFTYINTX
    BIGLEFTYINTX Light Load Member
    263
    210
    Nov 20, 2017
    .cdl pretrip is broken into 4 sections for testing. A,b,c and d.
    A is front of cab from the front edge of door forward and coupling. B is from door to rear of tractor and coupling. C is trailer and .Coupling. D is the whole thing
  8. spindrift
    spindrift Road Train Member
    3,235
    12,916
    Dec 2, 2014
    Texas
    I've never known a tester to ask for the location of a given part. It's your responsibility to know the parts, what they do and the location of those parts. If doing a partial, provide more info than less and even begin to start the identification of another area. Leave it to the tester to tell you, "OK, that's enough."
  9. Chinatown
    Chinatown Road Train Member
    77,796
    184,735
    Aug 28, 2011
    Henderson, NV & Orient
    I read somewhere that some drivers actually do a pre-trip. I went to a 10 day cdl school and the instructor said, "Wake up, get out of truck, stand between drives and sleeper, take a leak, hit the highway."
    Kyle G., spindrift and Omega7777 Thank this.
  10. Kyle G.
    3,902
    20,578
    Jan 23, 2016
    Eastern Iowa
    Why get out in the cold? Pee in a bottle or drill a hole in the floor.
    Chinatown Thanks this.
  11. Omega7777
    Omega7777 Medium Load Member
    392
    414
    May 21, 2018
    connect a tube long enough so you can pee while driving. just solved a first world problem there ;)
