parts to carry
Discussion in 'Ask An Owner Operator' started by jmcclelland2004, Jul 12, 2011.
  1. heavyhaulerss
    3,723
    2,041
    Dec 23, 2009
    AL/TN BORDER
    have a cut off tool, air side grinder or a air metal saw to cut off threaded rod on brake chamber if ever installing one & remember to screw nut on BEFORE cutting threaded rod.
  3. heavyhaulerss
    3,723
    2,041
    Dec 23, 2009
    AL/TN BORDER
    get an assortment of wire end connectors & a spool of wire. a continuity & hot wire tester. flashlight. metal flex funnel.
  4. heavyhaulerss
    3,723
    2,041
    Dec 23, 2009
    AL/TN BORDER
    soory , I see where you already have wire kit. too early with out my coffee. how about a couple spare air to air hoses?
  5. jmcclelland2004
    jmcclelland2004 Light Load Member
    204
    91
    May 22, 2011
    Modesto, Ca
    For the air cutoff tool I will have to get one of those to be honest some of the parts like the airbag and brake chamber are not so much so i can fix them but more so I have the parts and don't get overcharged on them when having roadside assistance.
    For the wiring and extra hoses I did get those and also got an extra set of glad hands as well but thanks for the advice.
  6. Mr. PlumCrazy
    Mr. PlumCrazy Road Train Member
    1,341
    606
    Jul 30, 2009
    Lexington NC
    I dont have half the things listed here If you carry all the things here you would need a tool/parts truck and you would would only be able to haul 20Klbs. I carry 1 gal of oil 1 antifreeze 1 spare tire 1 belt(water pump) a few tools 2 sets of vice grips duct tape and some baling wire
  7. Jolsen
    Jolsen Heavy Load Member
    951
    272
    Mar 6, 2010
    East of the big crick
    I carry all the same as Mr. PlumCrazy.
    The tools I carry is one of those Craftsmen tool sets that I bought just for the truck.
    Bailing wire it priceless.
    A small tackle box full of nuts and bolts wire terminals wires of asorted colors and a mini torch for shrink wraping wires.
    And one can of rustbomb(a little known product that left on bare metal will eat all the way threw with time)
  8. jmcclelland2004
    204
    91
    May 22, 2011
    Modesto, Ca
    With the things I am carrying and my empty trailer with full tanks I weigh in at 36,500lbs that leaves me with 43,500 for cargo or 43,000 is what I will look for I do have a sliding 5th wheel and sliding tandems on trailer so I should be able to shift the weight fairly well. Alot of the stuff is just having the parts so when it does happen I can just pay labor as I got the parts for a good price.
  9. BigJohn54
    BigJohn54 Gone, but NEVER forgotten
    1,972
    1,599
    May 13, 2011
    SW Missouri
    I don't carry any parts that I don't plan to install myself. I've done lots of different kinds of service work. For the most part you will find service guys make a certain amount on a job. It is made up of labor and parts markup. If you furnish your own parts they just make it up on labor.
    halfburn Thanks this.
  10. jmcclelland2004
    204
    91
    May 22, 2011
    Modesto, Ca
    well that sucks for my idea. I do have a fair a 201peice socket set and a 1/2 inch and 1 inch impact wrench so I guess there is a fair amount I could do on my own if I really wanted to. Part swapping (like the airbag for example) is normally fairly easy. Good point though I didnt really think about them just making it up in labor.
  11. jojos
    jojos Bobtail Member
    16
    Dec 3, 2010
    stl, mo
    rem the siphon to fill up filter
