Pass or Fail?
Discussion in 'Questions From New Drivers' started by WesternPlains, Aug 5, 2018.
  1. WesternPlains
    6,314
    54,525
    Sep 1, 2017
    Doing in cab brake test.
    Pumping brake to bring air down to cause brake to activate.
    It actuates at 25 psi on secondary tank.
    Primary tank well below 20 at that point.
    Pass or Fail?
  3. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,140
    Mar 5, 2016
    White County, Arkansas
    Fail.
    Regulations state 60 PSI or lower, you should get the warnings.
    By the time you get the alarm at 30 PSI or lower, there literally isnt enough air physically present in either primary or secondary to be worth a #### once you do find you need all of it now.
    Your application will pretty much go away along with the air at zero ppffth. in a few moments. If your truck has anything left at all it will be the spring brakes. Maybe. (It better.) but not on mountain ice or rain...
    That truck goes into the shop today, this minute and not one inch by anyone in regular service empty or loaded anywhere until that problem is found and fixed.
    BUMBACLADWAR and okiedokie Thank this.
  4. McCauley
    McCauley Medium Load Member
    635
    806
    Jun 23, 2013
    Are you talking about on the CDL test or in practical terms?
  5. SingingWolf
    SingingWolf Heavy Load Member
    782
    9,708
    Sep 14, 2016
    Steubenville, OH
    The alarm should come on at around 60. The SWITCHES should pop around 40.
    My question is, what temp was it outside?
    The reason I ask is because I've had switches not want to pop at 40 until the truck is thoroughly warmed up.
  6. Kyle G.
    Kyle G. Road Train Member
    3,901
    20,563
    Jan 23, 2016
    Eastern Iowa
    If memory serves me right (it usually doesn’t), the brakes must set themselves anywhere between 20-60, but idk if that is primary or seconday or either, so that sounds like a fail.
    WesternPlains Thanks this.
  7. WesternPlains
    6,314
    54,525
    Sep 1, 2017
    Thank you. You actually comprehended the question! It’s actually 20 to 40.
  8. WesternPlains
    6,314
    54,525
    Sep 1, 2017
    It’s pretty hot...90? Just got back from a run a couple hours earlier.
    This is hypothetical. Close, but not real. Just looking for understanding.
    SingingWolf Thanks this.
  9. 06driver
    06driver Road Train Member
    2,436
    3,434
    May 28, 2017
    CVSA says minimum 20 psi (maximum low?) for TPV.
  10. Buckeye 60
    Buckeye 60 Road Train Member
    1,229
    1,269
    Apr 19, 2018
    warning bell has to come on at 60 psi the red trailer should pop at 40 psi tractor useually around 25 .... if any of those ain't happening you have to take it in ..... I think it sounds like you are doing a static brake check like a dot officer would do and those are the numbers they are looking for and it fails for them you are getting towed and a nice little ticket
    SingingWolf, wore out and Coover Thank this.
  11. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    did you have switch on.
    wore out Thanks this.
