Passenger window doesn’t close.
Discussion in 'Volvo Forum' started by Roman78, Jun 25, 2021.
  1. Roman78
    Roman78 Light Load Member
    74
    27
    May 20, 2021
    Could t be a fuse or something Thank you
    KB3MMX Thanks this.
  3. gerardo1961
    gerardo1961 Road Train Member
    1,750
    616
    Feb 21, 2010
    Miami
    I have the some before was the swich in the door (30$) or the motor from the windows
  4. gerardo1961
    1,750
    616
    Feb 21, 2010
    Miami
    Can you close the windows from the driverside
    NavigatorWife Thanks this.
  5. Roman78
    74
    27
    May 20, 2021
    Nope. The driver side window works but im unable to close to passenger window.
    KB3MMX Thanks this.
  6. terryt
    terryt Heavy Load Member
    736
    777
    Apr 27, 2009
    it a wiring issue the harness has broke and got water in it and has shorted out. Need to hot wire the window up and unplug it because it will power down on it own. Very common not easy to find or fix The dealer replaced the switches in both doors and the motor on mine and it still would not go up and would auto down on it own.
  7. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    Roman78 Thanks this.
  8. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    Driver and passenger side have separate fuses....
    They're located in the dash fuse box...
    Personally have had this failure...
    Good luck!
