Pay Close Attention To Exit Ramp Speeds
Discussion in 'Trucking Accidents' started by justcarhaulin, Dec 30, 2017.
  1. justcarhaulin
    justcarhaulin Light Load Member
    153
    238
    Jul 20, 2015
    Let me start by not blaming anyone for causing this wreck as i wasn't there when it happened. This was in shertz tx on i10 westbound near san Antonio, Tx. As you may now in texas sometimes when you exit the freeway you get on a service road. The traffic on the service road( sometimes a one lane road) must yield to exiting traffic. The skid marks from the semi locking its brakes we pretty extensive. My opinion is that the semi exited at a high rate of speed then locked up its brakes when it ran out of room once on the service road. Some exit ramps are very short. Either way the results was in the semi laying on its side causing the tandems to come of the trailer. The cab was also crushed. I couldn't tell if there was a four wheeler laying under the big rig but judging from all the emergency response units that i saw, i dont think it the results were good. Prayers to the driver. Safe everyone.
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    That's a interesting wreck.
    I think he ran onto the ramp at or near highway speed and then realized no more ramp and he's about to go bye bye over the fields and yon. That heavy braking shows a total desire not to run off the pavement pretty much straight across. I don't think he thought about or had room to horse her in any direction to stay on that pavement. Once he hit that bank over he went. Shrugs.
    We have some ramps like that here in Arkansas. You will hop off at a very reduced speed on one in particular, that one will roll you at 10 mph and only offers about two truck lengths to slow down on before hitting one of the service roads. The angles are bad enough that you will not be able to see who is coming on your right without stopping in sort of a J situation to look out your pax window to eyeball anyone coming on.
    I find it interesting the trailer tandems became detached. I wonder if he rammed a 4 wheeler with it breaking the pins loose. And as we all know, those are mighty big pins to be busting.
  4. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    I think it is plain nuts if some one cant slow down to use any road. Exit ramps or otherwise. It isnt that hard to take your foot off the pedal. If your on cruise a light tap of the brake pedal will disable cruise. Those side roads (when I was driving) I would slow to 40 and ignore the idiots that tried to make me go faster.
    Guess that driver learned the hard way. Just hope they did it with a company truck. Expensive overhead if it is their own. Tho I do remember seeing a Werner on their side from trying to go down a clover leaf at freeway speeds.
  5. Lepton1
    Lepton1 Road Train Member
    12,647
    25,589
    Nov 23, 2012
    Yukon, OK
    I drive in Texas often. I absolutely hate the concept of frontage roads. Many exits you can gradually back out of freeway speed, but some have sharp turns that come up on you quick, with recommended speeds at 20 mph or lower. Often the signs posting the recommended speed are AT THE TURN.
    Oxbow Thanks this.
  6. stayinback
    stayinback Road Train Member
    3,911
    8,257
    Jan 24, 2014
    chicago,il
    texas is weird to me Lepton-
    You either got these exit ramps that go onto these service roads which you have to virtually stop almost-OR- You have these mile Long Flyover ramps 100 feet in the sky 1 lane wide
    Other than that...I Kinda liked Driving in Texas
    Oxbow Thanks this.
  7. rolls canardly
    rolls canardly Road Train Member
    1,639
    4,138
    Feb 7, 2009
    mt. pocono. pa.
    Route 80 Blakeslee, Pennsylvania On ramp redesign is another "Winner of designs of stupidity" award.
    They took a big eraser to everything there, when it was decided there was not enough merge area, and
    instead of leaving the adequate sweep entering Rt. 80, they shortened the radius, making the turn
    tighter, and necessitating you slowing more to make it, then used the newly found several hundred
    feet to make the merge area. So now instead of momentum carrying you thru and onto Interstate, you need to power out of an unnecessarily tight turn. I am sure the Designer who drew this up never visited the site. It is slightly uphill and impossible to enter now at speed. Flashers only. Terrible re-design. Unsafe.
    Traffic coming up to this onramp is climbing a gradual 1 mile incline, and has to move over creating chaos.
    Would you not think it would be a simple matter of just extending merge area and leaving turn alone?
    I thought the Interstate Highway System, been around since the 60's, had standards for these things?
    Texas comments brought this to mind; all exits as uniform as the terrain allows should be a standard.
    No surprises making room for human error.
  8. Muddydog79
    Muddydog79 Heavy Load Member
    820
    2,147
    Apr 14, 2016
    You must be talking about exit 98 westbound on interstate 30?
  9. x1Heavy
    34,016
    42,144
    Mar 5, 2016
    That's a pretty short exit, I was thinking of the old James st exit off US 67 north, you got about 2 truck lengths before you must stop at the sign there on a 5 mph bend. It's construction now so I hope they change the geometry.
  10. Muddydog79
    820
    2,147
    Apr 14, 2016
    10-4 That ones a dousey too.
    x1Heavy Thanks this.
  11. tech10171968
    tech10171968 Medium Load Member
    627
    851
    Nov 16, 2009
    Daytona Beach, FL
    Something else that lots of drivers forget: those recommended speeds posted at the offramps, unless otherwise stated, are usually designed with CARS in mind. When the traffic engineers suggested 20 mph as a safe off-ramp speed they really weren't thinking about semis at all. That's why I usually hit the ramps at least 5 mph slower than what's posted on the signs.
    mjd4277 and Lepton1 Thank this.
