PC, Apportioned Tags, and an Odd Question
Discussion in 'Questions From New Drivers' started by Crossbones, Oct 28, 2018.
  1. Crossbones
    Crossbones Light Load Member
    115
    66
    Mar 10, 2018
    Western NC
    Knowing full well that an intrastate vehicle with a regular Florida tag cannot cross state lines for work, I'm wondering if anybody can tell me the actual rules and laws surrounding leaving the state on PC. In other words I see no reason to spend money for a hotel on a short upcoming [personal] trip when I can just bring my own. Would I have some explaining to do at the first Georgia weigh station or is this no big deal?
    Thanks as always and stay safe out there.
  3. brian991219
    brian991219 Road Train Member
    3,020
    6,175
    Aug 10, 2013
    Lords Valley, PA
    Personal conveyance is simply an interpretation of hours of service regulations that allows you to drive a commercial motor vehicle in an off-duty status. It does not apply to fuel tax (IFTA) or apportioned registration (IRP). Being the nature of your truck is usually commercial you will have a hard time at the port of entry without a trip/fuel permit.
    Yes, a road tractor can be registered at a non-commercial vehicle and driven on the same tags you would drive a pickup truck, but that is not how your truck is registered at this moment. The IRP rules state that the truck must be apportioned if the primary use is to transport property, see quote below from the IRP Manual;
    You must register your vehicle(s) apportionately if the vehicle(s) travels or is intended for travel in two or more of the member jurisdictions and is used for the transportation of persons for hire or is designed, used, or maintained primarily for the transportation of property, and:
    • is a power unit having a gross or registered weight in excess of 26,000 pounds, or
    • is a power unit having three or more axles regardless of weight, or
    • is used in combination when the weight of such combination exceeds 26,000 pounds gross vehicle weight.
    The same rules apply to fuel tax (IFTA), the need for a fuel permit or decal is based on the primary use of the vehicle, not the fact it is being used as a personal conveyance at the moment.
    Ask yourself, is the savings on motel costs worth the aggravation of dealing with commercial vehicle enforcement? Also, what you save on motel expenses will be eaten up in fuel, assuming you have a normal personal vehicle with fuel economy in the mid 20 MPG range.
    Accidental Trucker Thanks this.
