Pending info
Discussion in 'Questions From New Drivers' started by Jackiejones1107, Oct 24, 2018.
  1. Jackiejones1107
    Jackiejones1107 Bobtail Member
    13
    6
    Oct 23, 2018
    Wilmington DELAWARE
    Has any1 evr gotten to orientation and was sent home due to pending paperwork?
  3. Opus
    132,533
  4. Allow Me.
    10,771
    12,598
    May 28, 2009
    Rancho Mirage, Ca.
    yes every orientation I ever attended had drivers sent home. ( for various reasons)
    x1Heavy Thanks this.
  5. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    You go through a number of drivers at orientation.
    Poof they are gone by lunch monday, some more gone by tues and pretty much wed all that is gone is gone.
    Then a few more when they are caught trying to omit some damming background stuff.
    Ive been sent home a few times, usually related to hearing. One time I botched a simple road test, it's so simple. Drive to lght make a left we dock at the safeway there in the back. And I botched it. Three months later Im back for another go. This time in a raging rain storm where you could not see the back of the container for love or money. Passed that with flyng colors. Boss looked me over and said I guess you are a keeper. But god help you if you get distracted like last time.
    I literally don't know to this day what happened to THEM. One day they were trucking and the next? Closed up.
  6. Moose1958
    Moose1958 Road Train Member
    15,296
    33,965
    Dec 17, 2010
    Williesburg, Virignia
    Yep. One of the biggest reasons is §391.23. Contrary to what you might read in these forums that driver qualification file is NOT something a carrier can take lightly! If they have not received these reports back some carriers have no choice but send you home.
    RSB34 Thanks this.
  7. brian991219
    brian991219 Road Train Member
    3,025
    6,217
    Aug 10, 2013
    Lords Valley, PA
    No, they do have a choice. The regulation requires that within 30 days from the date employment begins the carrier has made an inquiry in good faith for the background investigation as required. They are not under any regulatory obligation to withold employment until the investigation is complete nor are they obligated to withold employment if the previous emoloyer(s) fail to respond. They simply must document a good faith effort to comply, usually interpreted as three documented attempts. Then they have the option to report the precious employers failure to respond to FMCSA.
    Now that said, out of an abundance of caution many large motor carriers will withold employment until a satisfactory background investigation is complete. It is their right to exceed minimum compliance, but to blame it on the regulations is misleading.
    Bottom line, they need to better explain this since most drivers come to orientation believing they have already been hired, or at least hired on the condition of passing a drug screen and road test. Many drivers believe that companies have already done the background investigation before scheduling orientation. I know they don't due to the effort and cost as compared to how many prospective drivers never show up to orientation vs. how many may be sent home due to incomplete background checks.
  8. Moose1958
    15,296
    33,965
    Dec 17, 2010
    I should have took better care. Notice in the part that you quoted I used the (qualifier) some. What I was trying to say was some carriers by their internal rules will not complete the hiring process until that DQF is finished. This is because the FMCSA is so dang tough on this. Carriers have been busted by the FMCSA over that DQF. This tends to make some of these carriers practice an overabundance of caution.
    brian991219 Thanks this.
  9. brian991219
    3,025
    6,217
    Aug 10, 2013
    Lords Valley, PA
    Absolutely correct. Using unqualified drivers is surefire way to recieve hefty fines and place your authority in jeopardy.
