Personal Limit For Max Wind Speed
Discussion in 'Experienced Truckers' Advice' started by JC1971, Dec 15, 2018.
  1. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    It's call FREEDOM ;) they would rather see an oil rig then a wind turbine. Merica!!!
    Dave_in_AZ and Rideandrepair Thank this.
  3. otterinthewater
    5,592
    29,333
    May 10, 2018
    Santa Barbara, Ca
    You be careful meow.
    Dan.S, Rideandrepair and IluvCATS Thank this.
  4. otterinthewater
    5,592
    29,333
    May 10, 2018
    Santa Barbara, Ca
  5. Moosetek13
    Moosetek13 Road Train Member
    14,988
    19,046
    Nov 1, 2010
    Burnsville, MN
    The climate is changing, what do you expect?
    Whether it is man made or natural climate change, or a combination, it is changing.
    Get used to it.
    Rideandrepair Thanks this.
  6. Rideandrepair
    17,572
    56,924
    Aug 8, 2015
    What weather website is that?
    Lepton1 Thanks this.
  7. SteveScott
    SteveScott Road Train Member
    4,897
    16,809
    Nov 10, 2015
    There are high wind warnings up around Weed at least twice a month. As long as you're loaded with some weight and don't go too fast, you'll do fine. About 3 miles north of Weed is the choke point where the Shasta Valley meets the hills, and that's where the wind is usually the strongest. The nice thing about this area is that you're only looking at about a 30 minute drive in the windy area between Yreka and Weed and then you're out of it for the most part. Depending on which direction you're traveling, it's either a head or tail wind. Not usually a cross wind like you would see on the 80 across Wyoming.
    There are plenty of places to pull over in that area if the wind gets too strong for you.
  8. Lepton1
    Lepton1 Road Train Member
    12,647
    25,593
    Nov 23, 2012
    Yukon, OK
    That's a screenshot from the MyRadar app. I consult it frequently to making routing decisions. I have the wind layer and cloud layer turned on.
    It's pretty neat. You can see temperatures, forecasts, and wind directions and speed anywhere in the world.
    Broke Down 69 and Rideandrepair Thank this.
  9. Rideandrepair
    17,572
    56,924
    Aug 8, 2015
    Wow I really need to get up on technology !!!
  10. Lepton1
    12,647
    25,593
    Nov 23, 2012
    Yukon, OK
    I run a lot of loads in Tornado Ally. During the season that app is on almost continuously. It's saved my bacon many times.
  11. smokey12
    smokey12 Road Train Member
    1,734
    3,273
    May 30, 2012
    It is getting nuts. Lately I have been seeing stories that say the past two years the earth has been cooling because of the lack of sunspots. The Antarctic is getting larger, not smaller. Earth is ginna do what it wants and shake us off like parasites when it's ready. Great photo btw
    Dave_in_AZ Thanks this.
