Perspective 2021 VNL64T860 purchase
Discussion in 'Volvo Forum' started by 86scotty, Sep 7, 2023.
  1. 86scotty
    86scotty Road Train Member
    4,781
    13,125
    Aug 27, 2017
    Appalachia
    I may've found my next truck.
    2021 VNL64T860
    D13 455/1850 (NOT turbo compounding)
    2:79 Rears
    Globetrotter package
    just under 500k miles
    New drives and steers
    EGR cooler has been replaced, all other warranty stuff is small.
    Run by small fleet in the South, no rust, VERY clean, fleet has great reputation with local dealers
    No APU, has been idled nights (10k hrs. run time on 500k miles, which is about 20% idle time)
    ** This is roughly the same idle time as my 2015 which DOES have an APU
    May buy aftermarket warranty, Volvo warranty is up, 750k Ishift warranty left
    Thoughts? If you are anti-Volvo what are you reading this for? Not looking for negativity, looking for Volvo guy's thoughts. I know it's about ready for the mid life stuff, possibly One Box, turbo, etc.
    Blagoje, KB3MMX, Numb and 1 other person Thank this.
  3. ducnut
    ducnut Road Train Member
    2,683
    8,138
    Dec 31, 2010
    SPI
    When was the last overhead done? Were the injectors ever replaced? Were the pre- and post-sensors ever replaced? Has the CAC ever been pressure tested? Has the clutch actuator ever been replaced? Has the VGT actuator ever been replaced? Those are the common Volvo things I can think of.
    The EGR cooler being replaced is a biggie. There’s an inspection cover on it. Be sure and make inspections a regular part of your services, as a cooler that leaks will wreck the DPF cartridge. In fact, I’d almost want for them to split the can in front of me, to visually inspect the cartridge.
  4. 86scotty
    4,781
    13,125
    Aug 27, 2017
    Appalachia
    Not sure about overhead yet since some maintenance was done by the fleet but I plan to talk to them. I can only see warranty maintenance done by dealer. Pre/Post sensors yes, CAC has been tested since there was a leak and it was a warranty fix within the last year.
    Not sure about clutch actuator or VGT actuator.
    Not sure about injectors. Didn't D13's go to common rail and fix injector problems by 21?
    I'm definitely familiar with EGR cooler inspection and the damage it can do.
  5. ducnut
    2,683
    8,138
    Dec 31, 2010
    SPI
    I’m not sure of the changes on most recent engines. My ‘18 had to have injectors at ~500K miles.
    Volvos really need good shocks on them, to get the most out of their ride. I’d be doing that from the beginning.
    It sounds like you’ve got a good handle on this truck and are researching it right. I think, your mention of the extended warranty would be a great thing to consider. If it continues to check out, then, move forward.
  6. 86scotty
    4,781
    13,125
    Aug 27, 2017
    Appalachia
    Thanks @ducnut. Yep, shocks are cheap and easy. I've done them a few times on my 780. I just talked to my mechanic (again) and he confirmed that the injectors aren't nearly as bad a problem on the newer d13's as the later models. They can still be trouble but not nearly as common. It is high on my list of worries since this one has no APU and has been idled. So is a $5k One Box.
    I'm hoping to drop by the dealer that did the warranty work as soon as I can get there and this truck would definitely be going straight to my mechanic for a full run through, including overhead of course.
    Anybody else running 2.79 rears? I've got 2.64 and have enjoyed my 7.5mpg average over last few years. I don't think it will be much different but before yesterday I had never even heard of that gearset.
    ducnut Thanks this.
  7. ducnut
    2,683
    8,138
    Dec 31, 2010
    SPI
    The DPF cartridge is as easy as tossing into a steam cleaner or pressure washing it at the car wash. Only if the EGR leaked bad enough and long enough, would you need to replace it. My cartridge looked like concrete caked onto it. A young tech was beating on mine with hammer, showing me just how hard the stuff was.
    Our T680’s have 2.79 rears. I run 1215rpm, at 67mph, on 295’s.
    Siinman, Blagoje, KB3MMX and 1 other person Thank this.
  8. KB3MMX
    KB3MMX Road Train Member
    3,079
    2,596
    Dec 29, 2014
    Orrstown, PA
    Hey brother, with the Volvo extended warranty you'll get two years 250k added to the truck that covers all major components including emissions.
    I don't think you can go wrong for a $10,300 Volvo OEM warranty package to give you that kind of security
    ducnut Thanks this.
  9. 86scotty
    4,781
    13,125
    Aug 27, 2017
    Appalachia
    This isn't at a Volvo dealer unfortunately. I'm told the only extended warranty I can buy from the selling dealer or my Volvo dealer later is NTP warranty.
    ducnut Thanks this.
  10. Siinman
    Siinman Road Train Member
    5,569
    14,306
    Mar 5, 2017
    Kansas City, MO.
    Mine is a 2023 VNL 860 with the D13 500 HP and have the 2.79 RAR. I have 135K on it with no issues but do not idle the truck. If you get it bump it up to the 500 HP set up. I get around 8.8 MPG's with this set up running dry van light and heavy.
    Get a dump on the ECM and also check all the service records. Might be a good truck if they took care of it. I love my truck.
    86scotty, DUNE-T and ducnut Thank this.
  11. Siinman
    5,569
    14,306
    Mar 5, 2017
    Kansas City, MO.
    You should not have injector issues with this year.
    86scotty and ducnut Thank this.
