Pete 359 3406B Jake Switch
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Mar 12, 2024.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,356
    1,707
    Dec 4, 2019
    Three wires going into this four prong switch. 2 wires are going to the jakes and 1 wire is going down to the switch on back of pump. Other wire on the back of pump is going to the clutch switch. Which wire is continuously “hot”? image.jpg image.jpg image.jpg
  3. Tall Mike
    Tall Mike Road Train Member
    7,500
    35,495
    Aug 20, 2014
    The Hammer Lane
  4. Last Call
    Last Call Road Train Member
    7,568
    45,910
    Mar 15, 2021
    On which switch .? The switch on the dash ? I’ll be honest with you the only way I can tell you is your going have to test each wire on the dash switch because I can see in the picture somebody has been in the rutting around . I can tell you what color and # number it should be but some body has cut all the ends of the wires and run the same color wire. It should be one of the 2 wires in the middle terminals of that switch
    I will also tell you that more than likely the switch on the clutch peddle is probably bad and the switch on the pump you can adjust but it it controls your low idle which you want it set at 800 rpms
    Bean Jr. and mile marker 27 Thank this.
  5. mile marker 27
    1,356
    1,707
    Dec 4, 2019
    Yeah, it’s been rewired, cobbled in places and wire color means little, at this point. I’ve got a 359 wiring schematic but it only shows Cummins jakes. None of the wires at the switch are hot with key “on”. Unless something is wrong at the dash switch, then I’m guessing power, is coming from one of the wires at the switch on the pump? It then make a loop through the clutch switch, then up to the dash switch, then out to the jakes? Maybe I’m arse backwards on it??
    Last Call Thanks this.
  6. mile marker 27
    1,356
    1,707
    Dec 4, 2019
    I got a ton of stuff to do, especially on farm equipment. Drink a couple beers towards the end of the day and why I walked over and started tinkering on this is beyond me. I’m a glutton for this crap.
    Bean Jr. Thanks this.
  7. Last Call
    7,568
    45,910
    Mar 15, 2021
    The schematic for the power will be the same as far as where the power come from and the wire it’ just changes at the switch the difference is a Cummins is a 3 stage a cat is a 2 stage
    mile marker 27 Thanks this.
