Pete 359 fuel issue
Discussion in 'Peterbilt Forum' started by Asphaltcowgirl, Apr 5, 2016.
  1. Asphaltcowgirl
    Asphaltcowgirl Bobtail Member
    7
    Apr 5, 2016
    Have an 84 model 359. Has the up/down fuel switch on the dash.. truck will run then want to shut off, fiddle with the switch it will fire back up and run for a while then cut out again. Any ideas here?
  3. Bean Jr.
    Bean Jr. Road Train Member
    5,573
    9,929
    Mar 30, 2014
    If the switch is like the ones I had in my 379 and in my father's 281, that is for the fuel gauge. You probably have a different problem.
    rank Thanks this.
  4. Asphaltcowgirl
    7
    Apr 5, 2016
    Ah ok, thanks! Is that switch at all connected to fuel flow or delivery?
  5. Bean Jr.
    5,573
    9,929
    Mar 30, 2014
    On our trucks, it was only for the fuel gauge. A 359 may be different, but if the model before and after have switches for witch tank the fuel gauge is measuring, I would think it would be the same. Good luck finding the problem.
    rank Thanks this.
  6. Straight Stacks
    Straight Stacks Paper Cha$er
    2,930
    20,768
    Jul 18, 2015
    Alabama Gulf Coast
    rank and bullhaulerswife Thank this.
  7. Asphaltcowgirl
    7
    Apr 5, 2016
    Thanks y'all. I think you're right it's just for the gauges. Guess I need to check lines and such.
  8. AModelCat
    164,645
    First off, what have you got in it for an engine?
    -When where fuel filters last replaced?
    -Have you started fueling up anywhere new since this issue started?
    -Is there any possibility of there being an obstruction due to debris inside the fuel tanks?
    -Are the fuel lines original or have they been replaced?
    -I mean no insult with this question but does the truck have fuel in the tanks? Fuel gauges can be innacurate.
  9. Old school 362
    Old school 362 Medium Load Member
    392
    249
    Mar 6, 2016
    Pensacola Fl
    I would
    that is switch is for reading left and right fuel tank.
    rank Thanks this.
  10. Old school 362
    392
    249
    Mar 6, 2016
    Pensacola Fl
    Disconnect fuel return line. On top of left tank. Then apply air pressure to fuel line return nipple. Until you have fuel coming out of line. Then replace line and start engine. Easy way to prime . If you don't get fuel you have a filter issue.
    rank Thanks this.
  11. beemergary
    beemergary Light Load Member
    229
    112
    Apr 11, 2014
    I have a 84-359 and that switch is for right and left fuel level with one gauge. Should have a fuel pressure gauge. If you got atleast 30# means transfer pump is sending enough fuel thru filter to injector pump. Don't have a bad connection thru key to fuel on-off solenoid?
    rank Thanks this.
