Pete 379 air leaf suspension bushing replacement
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Jun 29, 2023.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,419
    1,739
    Dec 4, 2019
    I need to replace all 4 leaf spring bushings, that go in the spring hangers. It’s an air leaf suspension and was wondering if there was a particular procedure to do this the easiest way? Any places other than Pete that offer good quality?
  3. Big Road Skateboard
    7,328
    41,749
    May 2, 2021
    Start soaking those bolts in PB now, and make sure your dealer has the frogs available JIC.
    I'm pretty sure on my feet, so this ain't for everybody. I have a long bolt the same size as the bolt through the bushing. I stack the right size washer, stand on the frame, and drive them out with a sledge.
    The more wore out they are, the easier it will be
  4. mile marker 27
    1,419
    1,739
    Dec 4, 2019
    A couple are pretty wore out.
    Oxbow and Big Road Skateboard Thank this.
  5. Big Road Skateboard
    7,328
    41,749
    May 2, 2021
    Air hammer will get em pretty easy then
    Oxbow Thanks this.
  6. mile marker 27
    1,419
    1,739
    Dec 4, 2019
  7. Big Road Skateboard
    7,328
    41,749
    May 2, 2021
    Oxbow and mile marker 27 Thank this.
  8. mile marker 27
    1,419
    1,739
    Dec 4, 2019
    Can I torch them out?
    Oxbow Thanks this.
  9. Big Road Skateboard
    7,328
    41,749
    May 2, 2021
    Yeah, they're all rubber on the outside.
  10. Diesel Dave
    9,824
    34,132
    Jan 20, 2010
    Hesperia, Ca.
    Make sure you get the correct bushings, they all look pretty close, low air leaf, Air track, and air leaf.
    wore out, Oxbow and mile marker 27 Thank this.
  11. lester
    2,959
    8,098
    Jan 2, 2012
    NW, Iowa
    On my low air I torch the bolt head off and set the rubber on fire and let it burn. Knock the bolt out and what'd left of the bushing. Clean it out and install new. Pretty easy job. 30-60 min per side
