Pete 386 Weird wiring issue
Discussion in 'Trucks [ Eighteen Wheelers ]' started by djb379pete, Jan 11, 2021.
  1. djb379pete
    djb379pete Bobtail Member
    21
    21
    Aug 28, 2013
    Preston md
    Got a 2010 386 peterbilt that I’m having a weird issue with I can’t seem to figure out. So when you flip the turn signal switch to the right on the rear of the truck all the turn signals flash, same when you flip it to the left turn, and when you apply the brake the front drivers side parking light will light up bright. I’ve traced wires from the cab to the rear of the truck and can’t find anything chaffed or rubbing and I’ve replaced the turn signal switch as well. When your hooked up to a trailer it’s only the truck acting up, trailer turn and brakes function normal. Any insight on where to look next or what to do? Thanks for any responses
    D.Tibbitt Thanks this.
  3. kwswan
    kwswan Road Train Member
    2,044
    11,240
    Jul 26, 2009
    mcminnville,tn.
    Sounds like a bad ground
    djb379pete, BoxCarKidd and D.Tibbitt Thank this.
  4. D.Tibbitt
    157,290
    I had similar problem but it was in my trailer. Left signal would flash all lights, same with breaks. It turned out to be bad ground in the pigtail was causing it. But like i said it was on trailer. I would imagine u have a bad ground somewhere on the truck.
    djb379pete Thanks this.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,555
    6,643
    Aug 26, 2014
    I would start by disconnecting harness one at a time. Each rear light. Any connectors in the harness down the frame? Then move to the front.
    Had a 388 with a bad chassis control module. It was behind the trans on the left inner frame rail. Believe all the turn signal and markers run through that. You may or may not have one.
    That truck had a harness rubbed through on the rear cross member which probably damaged the module.
    I would try that with trailer cord connected and disconnected. And yes check grounds.
    D.Tibbitt and djb379pete Thank this.
  6. djb379pete
    21
    21
    Aug 28, 2013
    Preston md
    Thanks guys, a bad ground hadn’t even occurred to me.
  7. Jimmybahlerrepair
    Jimmybahlerrepair Bobtail Member
    Apr 6, 2023
    Mechanic here. I have a 2009 Peterbilt 386. In our shop very similar issue.
    Ive noticed alot of lighting issues with these and Kenworth. Both have a module (chassis node) on the frame has three mounting bolts and three electrical connectors. Changed it and bingo. Unfortunately there very expensive. 1400 plus..
    Jimmy
  8. Jimmybahlerrepair
    Apr 6, 2023
    Work on these all the time . Theres a chassis node on the inside frame rail on driver side. Has three mounting bolts and three electrical connectors. Start theres very common and expensive. Find another working one and try it hope this helps
