Pete 389 floor board vibration?
Discussion in 'Ask An Owner Operator' started by Wespipes, Oct 16, 2020.
  1. Wespipes
    Wespipes Road Train Member
    1,037
    1,816
    Jul 14, 2019
    2019 pete x15 performance 2350. 565 hp 1850 tq eaton 18sd 120k miles. I've seen a few posts with what sounds like a similar concern I'm having. I can feel what seems like something hitting the floor of my truck in higher gear/speeds. Starting around 6th gear. Hear it most in my 7 high or 8 low and high. Sounds like every rotation. I can hear it and feel it. Slight vibration at my feet with it as well when pulling heavy loads up hills. My wife can't hear it when she's in the sleeper. In other posts some suggested getting the driveline balanced. Is it possible the clutch needs to be adjusted? I've had a mechanic i trust go under and look at the drive lines and they said everything looked good. Its been doing this the last 40k miles or so
  3. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    Does it change when you put your foot on the clutch?? Not enough to disengage it or anything just just enough to move the throw out bearing around a little.
    Klleetrucking Thanks this.
  4. JonJon78
    JonJon78 Road Train Member
    7,245
    43,249
    Jul 1, 2018
    How can the mechanic tell if a driveline angle is off by just visually looking at it?
    Roberts450 and feldsforever Thank this.
  5. User666
    User666 Medium Load Member
    346
    888
    Sep 22, 2020
    Northeast Ohio
    Some are so bad it's painfully obvious.
  6. Wespipes
    1,037
    1,816
    Jul 14, 2019
    They just made sure everything was tight. So after researching i found it could be clutch needing adjustment, driveline needs balancing, tires need balanced. So I took it to my mechanic and im having all 3 done to be safe lol.
  7. JonJon78
    7,245
    43,249
    Jul 1, 2018
    Clutch adjustment is one of the steps in checking the driveline angles anyhow. Seems to be a common problem with these 389's...
    Luckily I haven't had any further issues with mine since getting it fixed, seems to be a recurring problem for some folks.
    Good luck.
  8. Wespipes
    1,037
    1,816
    Jul 14, 2019
    I found a YouTube video on how to do it myself. If I wasn't getting my driveline looked at i would've tried it myself. If this fixes the problem and it starts up again. I'll just adjust it myself. Looks like I could do it in prob a hr or even less.
  9. Lyle H
    Lyle H Road Train Member
    1,292
    2,942
    Apr 16, 2014
    Please explain how adjustment of the clutch relates to driveline angle.
    AModelCat Thanks this.
  10. Roberts450
    2,237
    3,638
    Feb 6, 2016
    Throw out bearing is starting to ride on the clutch fork and transmitting the vibration through to the floor and when it starts it normally shows up in higher gears under higher loads. @Wespipes should have noticed the free play being little to none if this actually is the cause of the vibration/noise.
    With that being said the clutch has nothing to do with drive line angles.
  11. JonJon78
    7,245
    43,249
    Jul 1, 2018
    I should have worded it different, its one of the steps in the process that peterbilt uses while diagnosing a driveline vibration issue.
