Pete 579- sleeper 12v outlets not working?
Discussion in 'Experienced Truckers' Advice' started by JReding, Oct 4, 2018.
  1. JReding
    JReding Road Train Member
    1,957
    3,510
    Sep 8, 2014
    Puyallup, WA
    I didn’t think too much of it when I found out that only one of the two outlets in the sleeper works in my 2016 579. Now that I’m test driving one of our 2019s tomorrow (I’m spending tonight in it now), I’ve found out that neither outlet works in this truck! Is this a common problem with these trucks, and is there a quick fix for it?
  3. J Rich
    J Rich Medium Load Member
    363
    380
    May 28, 2018
    Atlanta Ga
    Check fuses?
  4. Highway Sailor
    Highway Sailor Road Train Member
    1,328
    1,659
    Nov 23, 2011
    Erie,Pa.
    The sleeper fuse box was next to the drivers side box door under the bunk in the 2014 579 I had.
    JReding Thanks this.
  5. Numb
    Numb Crusty Curmudgeon
    4,319
    10,260
    Jan 30, 2012
    Charlotte, N.Carolina
    may only work with shore power hooked up or the APU running.
  6. JReding
    1,957
    3,510
    Sep 8, 2014
    Puyallup, WA
    Yeah, they’re good. I’m guessing a wiring issue?
  7. JReding
    1,957
    3,510
    Sep 8, 2014
    Puyallup, WA
    I found two more outlets up on a top shelf, they both work. The two next to the climate controls are the problem ones. All I can figure is maybe some kind of wiring problem..?
  8. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    I don't recall it working in the last FL I drove either. I got it new. A 16 model. So it's not just pete.
  9. Espressolane
    18,678
    117,061
    Check the circuit breaker on the distribution box.
    Also check the connectors for the outlets.
  10. Krazzykat trucker
    Krazzykat trucker Bobtail Member
