Pete air leaf to low air leaf
Discussion in 'Peterbilt Forum' started by Carolinacat, May 30, 2017.
  1. Carolinacat
    Carolinacat Bobtail Member
    Can Pete air leaf be swapped to low air by just unbolting all the air leaf suspension... the brackets ,springs,bags etc and bolt in low air equivalent. All without changing the rears out. Or are the rearends brackets different?
  3. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    Probably need the rear end brackets to as you will need to make sure your driveline angles correct all the way up to the transmission.
  4. Carolinacat
    You talking about cutting them off the donor rears.
