Pete won’t start again
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Loaderlou, Sep 25, 2020.
  1. Loaderlou
    Loaderlou Medium Load Member
    342
    131
    Feb 24, 2014
    Hi friends. Well he we go again, my truck won’t start. In my previous post I said that I don’t get anything when I turn the key. Nothing, zip, zero, nadda. I’ve changed the starter, the key switch, the firewall relay, the 150 amp circuit breaker in the rail. Thoroughly cleaned the battery posts and cables. It was starting for about 2-3 weeks but now it’s not. I don’t know anyone who’s had this problem. Any ideas please.
  3. lester
    2,956
    8,085
    Jan 2, 2012
    NW, Iowa
    Try jumping the starter at the solenoid with a screwdriver? If that works would eliminate the starter and starter solenoid from your problems
  4. 6wheeler
    6wheeler Road Train Member
    2,696
    4,774
    Aug 30, 2009
    I have this problem all the time with every truck I own. The cracks and pot holes in the road shake everything loose, starters, battery you name it. I gave up on the truck battery that have the nut that you tighten down because they'll never stay tight hitting the rough roads at 65. I put top post battery in and changed the cables.
    Just the other day starter cable was loose at the starter and wouldn't start.
  5. pavrom
    pavrom Road Train Member
    3,216
    7,408
    Apr 29, 2012
    NE illinois
    Check ignition wiring ...could be loose
    Dave_in_AZ and skipgears Thank this.
  6. loudtom
    loudtom Road Train Member
    1,717
    2,806
    Aug 26, 2016
    My truck was having some trouble starting recently as well. Sometimes it wouldn't engage the starter, and the times where it did, it would kind of hesitate and act sluggish. Just cleaning the connections wasn't enough, I had to cut off one of the ends to the starter cable and crimp on a new one to fix the problem. In my case it was obvious, I could see the corrosion and frayed strands where the heat shrink tubing was exposed. This was one of the wires on the starter end, not the battery side of the cable.
    Dave_in_AZ Thanks this.
  7. Loaderlou
    342
    131
    Feb 24, 2014
    Thanks everyone for the comeback. I have 986000 on her. It has the original cables and when I cleaned everything in the battery compartment I could still see corrosion inside the rubber coating. I got as much a I could off but now I’m wondering if I should just go ahead and replace all the cables. What say youze guys. Yes I’m from NY
  8. Loaderlou
    342
    131
    Feb 24, 2014
    Hey Lester. I have an MT39 with the relay on it. Which of those wires ( 3 of them ) should I jump to the big stud on the solenoid
  9. lester
    2,956
    8,085
    Jan 2, 2012
    NW, Iowa
    Ha good question. I just start poke around till something sparks or moves!! You need to power to solenoid so cross main starter power to the small nut that gets signal from key switch. Might have to use to screwdrivers. This is shade tree mechanics at its best. Follow my advice at your own risk
  10. lester
    2,956
    8,085
    Jan 2, 2012
    NW, Iowa
    Sorry so many typos. 2 screwdrivers. You need to get power to the terminal that is normal energized by the key switch. On mine I have to use two screwdrivers touching each other one on starter positive and other on solenoid energizer stud.
  11. Loaderlou
    342
    131
    Feb 24, 2014
    Gotcha.its a 2003. This new stuff is bery confusing
