Peterbilt 359 lock cylinder
Discussion in 'Peterbilt Forum' started by Dexterr, Sep 2, 2012.
  1. Dexterr
    Dexterr Medium Load Member
    384
    328
    Jul 25, 2011
    Lafourche parish
    Ok, my doors don't lock with the keys so I have to leave vent window unlock and I can't unlock from the sleeper doors do anyone know where I can get we cylinders with keys?
  3. oilfieldtrash
    oilfieldtrash Light Load Member
    226
    107
    Oct 17, 2009
    Jones,Oklahoma
    You may be able to pull the cylinders out and take them to a good locksmith and he should be able to make keys for the ones you have. I have done that for a house that I had and a truck. They are not that hard to pull out if they are anything like a 379. They just have a clip holding them in. Or you could check with Peterbilt but that is obvious.
    lonelyswmtrucker Thanks this.
  4. Dexterr
    384
    328
    Jul 25, 2011
    Lafourche parish
    Thanks will do,I know where a dozen parts truck at I'll most likely get them made thanks again
  5. flc120
    flc120 Heavy Load Member
    916
    122
    Jul 11, 2012
    Miami,FL (yeah i know :( )
    yea just goto your local locksmith he should have new cylinders for you.
  6. oilfieldtrash
    226
    107
    Oct 17, 2009
    Jones,Oklahoma
    I think the cylinders may be a Peterbilt or atleast a Paccar only item. But a good locksmith should be able to either change the tumblers inside the cylinders or just make keys for those particular cylinders.
  7. Dexterr
    384
    328
    Jul 25, 2011
    Lafourche parish
    Live replaced with all new locks and tumblers feels good to have locking doors now
  8. The Admiral
    The Admiral Heavy Load Member
    894
    561
    Jul 18, 2010
    Akron,Ohio
    I spray white lithium into the key slot. It does not freeze and the locks work easier. I keep a can in the truck and give them a shot every once in a while.
  9. 04SSHD
    04SSHD Light Load Member
    110
    53
    Feb 7, 2011
    Henderson, NV
    I know you got the issue solved, but for future inquiries...I was told there are only 23 keys for the old peterbilts. The dealer suggested I bring my truck down and they can try their master set and find the key code. I was asking because my bunk lock doesn't match the truck doors and ignition.
  10. Texaskenny1322
    Texaskenny1322 Bobtail Member
    Freight defense, I just ordered full replacement cylinders for all doors and ignition with new keys. Very well priced and arrived in 3 days of purchase
  11. Dexterr
    384
    328
    Jul 25, 2011
    Lafourche parish
    Tell me how it went I've replaced all except ignition
