Peterbilt 387 CB Antenna location...
Discussion in 'CB Radio Forum' started by Smaggs, Sep 23, 2012.
  1. Smaggs
    Smaggs Pie Crust
    1,405
    698
    Apr 12, 2011
    Pittsburgh, PA
    Just wondering. I hate the factory coax. The antennae double as the radio antenna for the stereo, too!
    I want to run my own coax, but I don't know where I can mount my antenna. I'd be fine with mounting just one somewhere, but I'm not sure where I should mount or where I should run my coax cable. I have a pair of firesticks (the tunable ones) I could either do a dual configuration, but I'd rather just use one. I haven't selected any mounting hardware yet, because I don't even know where to mount the thing. Any suggestions, preferably with a photo, would be greatly appreciated!
    I'm also trying to keep it simple... hence only using a single antenna, just in case I don't stay in this truck for long. I'm a company driver.
    Here's a pic of my truck for reference.
  3. country29
    country29 Medium Load Member
    518
    157
    Feb 27, 2010
    there should be a mount for the mirror on the door, but i dont remember where I saw them, only thing with mounting them that low is you need to use a 5-5.5' francis,firestik, etc or you can get 1 of the mounts for the rear that mounts to the side fairing brackets and wraps around to the outside of the side fairing, I have seen these on walcottcb.com those are the 2 ideas that come to mind that work ok.
  4. Smaggs
    Smaggs Pie Crust
    1,405
    698
    Apr 12, 2011
    Pittsburgh, PA
    Sounds good. I saw the freight liner Cascadia mirror mount before. Maybe it works on a Pete I just have to be careful not to drill or otherwise damage the truck in any way to use it.
    Thanks for the suggestions!
  5. stacks
    stacks Road Train Member
    1,547
    850
    Oct 27, 2011
    Emerald Isle
    just out of interest friend what type of radio will you be running there and do you shoot skip across the pond '
  6. Smaggs
    Smaggs Pie Crust
    1,405
    698
    Apr 12, 2011
    Pittsburgh, PA
    Galaxy dx 979 it's tuned and peaked. I have a linear, but don't use it. Not hooked up. I don't think I could shoot that kind of skip with my little radio!
  7. Smaggs
    Smaggs Pie Crust
    1,405
    698
    Apr 12, 2011
    Pittsburgh, PA
    I wound up putting one of my firesticks on a mount on the back of my tractor at the top of the metal handle on the left wing. Sticks up just a little above the top of the truck and I get fantastic SWR readings now. I hear good and now when I key up, I don't hear it through my stereo speakers! I ran a K40 weatherproof coax through my toolbox door and out the slot below my bunk into my cab to reach my radio. got the mount and cables with points! Much happier!
  8. KentuckyReject
    KentuckyReject Light Load Member
    104
    47
    Oct 7, 2012
    Viper, KY
    I've got my firestik mounted like that, great swr but the fact that the majority of the antenna is blocked ruins most of what my cobra 200 puts out. Really need to find a suitable solution so I can use my monkey made and get out better. The Cascadia mount won't work because it is fitted to that specific mirror using bolts already in place to attach mount. This is like pulling teeth trying to get a solid solution
  9. WCM
    WCM Light Load Member
    193
    38
    Oct 10, 2010
    columbus ohio
  10. KentuckyReject
    104
    47
    Oct 7, 2012
    Viper, KY
    Right I've seen that but wouldn't the whip of a MM beat your truck
  11. KentuckyReject
    104
    47
    Oct 7, 2012
    Viper, KY
    I bought a mount that is similar to the outback, it works better but I'd still rather find a solution to get more antenna in the open air rather than be so close to the truck.
