Peterbilt 387. Dead batterys again.
Discussion in 'Experienced Truckers' Advice' started by 6wheeler, Oct 11, 2017.
  1. 6wheeler
    6wheeler Road Train Member
    2,696
    4,774
    Aug 30, 2009
    Anyone else have the same problem with batterys going dead if you don't run the truck every 2 or 3 days?
    New battrys. Cables. Starter. You name it its been replaced at least twice.
    I think its the computer that runs the automatic transmission. Not sure though
  3. Gunner75
    Gunner75 Road Train Member
    5,701
    9,076
    Mar 17, 2014
    Jackson Center Ohio
    Gotta ask the obvious, do you have an inverter that's staying on?
    Dave_in_AZ Thanks this.
  4. 6wheeler
    2,696
    4,774
    Aug 30, 2009
    Nope
  5. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    do you have DEF? there is a heater in that.
    do you have a fridge?
    the computer systems do take a very small amount of battery power, but that should not be enough to cause the batteries to go dead.
    the only other thing i might suggest is some sort of "battery tender" to keep a trickle charge on the batteries.
  6. Gunner75
    5,701
    9,076
    Mar 17, 2014
    Jackson Center Ohio
    How old are the batteries
  7. buddyd157
    13,582
    34,899
    May 25, 2017
    under a shade tree
    i wonder too how good and adjusted is the alternator belt, and the alternator output for both amp and volts. it the alternator is not producing enough, it will not keep the battery at a full charge.
  8. Aradrox
    Aradrox Heavy Load Member
    900
    622
    Jan 21, 2016
    Easiest solution would probably be install a Killswitch at the battery box
    Moosetek13 Thanks this.
  9. 062
    062 Road Train Member
    6,345
    34,004
    Oct 20, 2013
    That's got to be a fairly big draw. If you have a temp gun start taking readings in you fuse box and any where you have a relay after the truck has set a while.
    6wheeler Thanks this.
  10. 6wheeler
    2,696
    4,774
    Aug 30, 2009
    6 months
  11. 6wheeler
    2,696
    4,774
    Aug 30, 2009
    4 batterys. It smokes the kill switch. Already tried it.
