Peterbilt 387 electrical problem help
Discussion in 'Trucks [ Eighteen Wheelers ]' started by speeedy, Aug 25, 2013.
  1. Samer
    Samer Bobtail Member
    Hello,
    Im looking to by peterbelt truck ,
    I found 387 modules ,43000$
    Do you advice me ,or not
    Thanks.
  3. what year?
    what motor?
    what transmission?
    how many miles?
  4. pushbroom
    pushbroom Road Train Member
    1,790
    7,400
    Sep 1, 2012
    Sounds like a steal! get it while its hot!
  5. 387pete
    387pete Bobtail Member
    Sometimes our 387 when I go to start it no power in cab then later it starts. It cut off once as I was creeping to a stop another time I shut truck off about 20 minutes later no power in cab then a few minutes later it came back on. The first time this occurred was no power to cab after being parked overnight
  6. Dairon00
    Dairon00 Bobtail Member
    8
    Any update on what the electric problem was
  7. BubbaCox
    BubbaCox Bobtail Member
    26
    11
    Jul 2, 2017
    I was wondering the same thing.
  8. bavarian
    bavarian Heavy Load Member
    730
    785
    Feb 13, 2014
    Winnipeg
    The truck has 4 electric modules. Each has its own fuse in the battery box.
    I replaced my starter cables one day. The next day, the trailer lights didn't work. Turned out I broke one wire at the connector. The fuses are located at the front of the battery box.
    The four main modules are: right side firewall in engine compartment, glove box, sleeper and trailer control box in frame rail under rear end of cab.
  9. Wesley E
    Wesley E Bobtail Member
    Jul 10, 2023
    Hey , can you tell me/us what it took to fix your truck? I’m catching HADES trying to fix mine
    Flippwilson68 Thanks this.
