Peterbilt 389 Speedometer issue
Discussion in 'Peterbilt Forum' started by Cg102447, Jun 15, 2021.
  1. Cg102447
    Cg102447 Bobtail Member
    Jun 15, 2021
    Thanks Received:
    Having an issue with a speedometer on a 2015 389. speedometer has power and sweeps on initial key on but does not read speed. Both speed sensors are working correctly and wiring ohms out correctly to ECM.
    Any ideas?
  2. Zmmdawg
    Zmmdawg Bobtail Member
    Jun 15, 2021
    Thanks Received:
    Mine did the same. Then my Tachometer started showing false RPMs. Ended up being my cluster in the dash. Not cheap either
