peterbilt air window
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by kcayson78, Mar 8, 2021.
  1. kcayson78
    kcayson78 Bobtail Member
    7
    Mar 8, 2021
    have a 98 pete with air operated windows driver side leaks down a quarter inch replaced regulator and switch still leaks any help would be much appreciated
  3. bad-luck
    bad-luck Road Train Member
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
    Had a similar issue, I have a 2000 379. The air lift cylinder is most likely leaking. Its expensive, over $500
  4. Don379
    Don379 Heavy Load Member
    714
    1,286
    Jan 7, 2021
    I wish i had an air cylinder problem. HEll i gotta leave over the passenger seat and crank down my window in my 379 lol
    Last Call, NightWind and Dexterr Thank this.
  5. bad-luck
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
  6. kcayson78
    7
    Mar 8, 2021
    I replaced that and the switch
  7. kcayson78
    7
    Mar 8, 2021
  8. pavrom
    pavrom Road Train Member
    3,215
    7,408
    Apr 29, 2012
    NE illinois
    I have 2 if anyone interested , replaced 1 year ago , just replaced doors with 389 doors ...have to check if driver side not damaged ...would let it go for cheap
  9. Don379
    714
    1,286
    Jan 7, 2021
    Can I convert my 379 passenger door to air. Or is there too much involved inside the door
  10. pavrom
    3,215
    7,408
    Apr 29, 2012
    NE illinois
    Its not worth it , too much involved ..unless you have free parts and ton of time . I installed 389 doors on my 2000 379 , driver loves it .
    Don379 Thanks this.
  11. Don379
    714
    1,286
    Jan 7, 2021
    thats all i needed to know. thanks pal
    Can i install the rear view mirrors on the 389 doors? Im not a fan of how they mounted the mirrors to the body of the truck on later 379 and 389 trucks
