Peterbilt Brake Valve Replacement/Leak
Discussion in 'Peterbilt Forum' started by grainhauler, Mar 16, 2012.
  1. Miket41
    Miket41 Bobtail Member
    Workin on a 2001 Pete 378 when I push buttons in leaks air out center exaust port on abs relay valve rear axle anyone know what could cause that ?
  2. AModelCat
    165,353
    Likely a failed brake chamber. Chock your wheels on level ground, release brakes. Try and pinch off the SERVICE lines to each chamber, one at a time. If you pinch off a line and it stops leaking, there's your failed chamber.
  3. Salteedogg
    Salteedogg Bobtail Member
    7
    Jan 18, 2018
    Did you guys figure this out? My brake lights are stuck on, I’m getting pressure at the sensor. I already resealed the bendix under the brake pedal and the 1 about 2 foot behind it.
