Peterbilt Cat C15 oil pressure problem
Discussion in 'Peterbilt Forum' started by trs100, Feb 14, 2012.
  1. trs100
    trs100 Bobtail Member
    18
    Jan 6, 2012
    Hi,
    Does anybody know what is the normal oil pressure for C15 on idle when the engine is hot or cold?
    I`m getting around 20-30 psi on idle with hot engine since the manual says it needs to be between 40 and 80 psi.
    At 1200 rpm oil pressure is around 60 psi.
    Thanks!
    CruzControhl2 and suuprmnn Thank this.
  3. Mommas_money_maker
    Mommas_money_maker Road Train Member
    1,122
    765
    Oct 2, 2011
    North Carolina
    How many miles since last oil change and are you full of oil on the dip and how many miles on the engine?
    Expeditor Thanks this.
  4. trs100
    18
    Jan 6, 2012
    It has 1 007 000 miles and the oil is changed about 1000 miles ago and has lucas oil stabilizer.
  5. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    Sounds about what all our cats are running at
    KB3MMX Thanks this.
  6. trs100
    18
    Jan 6, 2012
    So is it a normal to be 20-30 psi on idle.
    The strange thing is that before it was around 60 when pulling and now goes no more than 45 psi with load.
  7. truckmechanic
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    Have you ever rolled I'm main bearings the oil pressure relics valve might be getting week what oil filter are you running
    KB3MMX and Kenworth kid Thank this.
  8. Mommas_money_maker
    1,122
    765
    Oct 2, 2011
    North Carolina
    I was thinking rods and mains bearings are due for change, they used to be changed around 725,000 and that would definitely cause a loss of pressure along with oil pump
  9. machesha1
    machesha1 Bobtail Member
    4
    Feb 16, 2014
    Trs100.... I Have same problem on my cat c15 with 825000.
    Did you find out what was wrong with your engine?
    or give an idea what can be wrong.
    w9l Thanks this.
  10. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    before you start throwing parts at it. do an oil sample to see what metals are in it. it might be the oil filter collapsing or the brand of oil if you started using a different brand. it maybe fuel dilution ie bad injector or injector o-rings. oil sample will show that also.
    KB3MMX and Expeditor Thank this.
  11. machesha1
    4
    Feb 16, 2014
    Did the oil test....all good....Using same tipe of oil.
    On idle with 600 rpm i have 25psi with 180 F water temp.
    On 700 rpm 30psi
    On 750 rpm 38psi
    Full load 60psi and 50-55psi up hill with 210F water temp.
    Goind down hill 1500 rpm 60-63 psi.
    Conected to computer.... reading same like the gauge .
    rydr Thanks this.
