My oil pressure just dropped to 20psi at an idol tonight and gained quit a bit more blow by. Any ideas? It's an 05 acert
Peterbilt Cat C15 oil pressure problem
Discussion in 'Peterbilt Forum' started by trs100, Feb 14, 2012.
Page 3 of 5
Is it running rough? What serial# prefix is the engine.
How many,miles since last oil change?
What filters you have ? -
I’m having the similar issue but my accert is around10-20 psi at 600rpm and 55 psi at 1500 rpm any suggestions?
how many miles on motor?
have you had any oil samples done?
when was last oil change?
does the truck have a blowby tube?
if blowby on truck. what's coming out?
smoke? what color?
oil?
KB3MMX Thanks this. -
I have not had any samples done.
Last oil change was about 4K ago
It has a little bit of blowby and white smoke is coming out.KB3MMX Thanks this. -
how many miles. what year
It has 260k and it’s a 2006KB3MMX Thanks this.
that is incredibly low miles for that motor to be that low in pressure.
What oil are you running? I've noticed a difference in pressure from rotella and delo. I'm running delo on a fresh overhauled engine and it runs at about 63pounds at 1500rpm. It was higher when I had rotella in it before.KB3MMX Thanks this.
Page 3 of 5
