peterbilt fuel tank brackets
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by krazzyboi_44, Aug 31, 2023.
  1. krazzyboi_44
    krazzyboi_44 Light Load Member
    298
    42
    Apr 30, 2008
    BAton Rouge,Louisiana
    What's the easiest way to remove the huck bolts from the fuel tank brackets without using a torch?
  3. Last Call
    Last Call Road Train Member
    7,568
    45,912
    Mar 15, 2021
    Use a die grinder & a cut off wheel grind the huck head either off or almost off then knock the huck out with either a air hammer or hammer & punch
    Oxbow, Goodysnap and Diesel Dave Thank this.
  4. MRMTRANS
    MRMTRANS Medium Load Member
    408
    441
    Apr 28, 2015
    Like said, but you might want to use a diamond cutoff wheel instead of the less expensive black abrasive wheels. They cut a lot quicker and they are a lot more durable. I've never cut hug bolts, but was told to be wary of them "flying" off at the end of the cut.
    Oxbow Thanks this.
  5. Cdemars316
    Cdemars316 Road Train Member
    1,034
    6,676
    Nov 10, 2018
    They are under like 3000 lbs of pressure or something insane like that, had them put dents in my kids vehicle that was like 30 feet away when I was cutting some out in the cab of my truck
