Peterbilt SmartAir system
Discussion in 'Trucks [ Eighteen Wheelers ]' started by stark21, Apr 25, 2021.
  1. stark21
    stark21 Light Load Member
    129
    5
    Jul 25, 2010
    Virginia Beach
    does anyone how the size of the AGM battery that the SmartAir system uses, believe I need to replace the batteries as system only works for 10 minutes and completely drains the Aux batteries to 0. by looks of batteries probably original from factory. it's a 2017 pete 579..
  3. Goodysnap
    Goodysnap Road Train Member
    3,774
    9,201
    Jul 12, 2017
    Not trying to talk you out of AGM, but have you considered installed traditional deep cycle marine batts?
    Those AGMs are friggin expensive.
    I can get you the factory battery capacity in the morning.
    spsauerland and rydr Thank this.
  4. stark21
    129
    5
    Jul 25, 2010
    Virginia Beach
    I just figured you had to use AGM for that system, if not yeah I can do Marine Batteries or any other type of battery that will work, would also like to run my inverter off them.
  5. Goodysnap
    3,774
    9,201
    Jul 12, 2017
    We sure do replace alot of them. I often wondered how a traditional lead acid deep cycle would last in comparison. I dont think the system would know the difference as long as the voltage is the same.
    Your typical cranking batts are a no go.
    I will still get you the specs. I know the brand is Odyssey
  6. stark21
    129
    5
    Jul 25, 2010
    Virginia Beach
    yeah wasn't sure about normal starting batteries even though the main batts are 950CCA.. the only thing I do know is the group size is 31 for the agm
  7. dclerici1
    dclerici1 Medium Load Member
    527
    1,589
    Aug 1, 2012
    Shell Knob, Missouri
    I had a set of AGM’s in a new ‘12 Western Star and they lasted 13 months. Never again.
  8. stark21
    129
    5
    Jul 25, 2010
    Virginia Beach
    that's strange most of the shops I have been to have always said these AGM's that peterbilt uses are really good but then if these are original there from a 17 pete 579 so 4-5 years old now.
  9. Goodysnap
    3,774
    9,201
    Jul 12, 2017
    Odyssey xtreme# 31-PC2150 is factory
    Northstar # NSB-AGM31 is another popular option.
    spsauerland Thanks this.
  10. stark21
    129
    5
    Jul 25, 2010
    Virginia Beach
    looked those up and dam your right those are crazy prices, I called my peterbilt shop and they have 20 that have been on order for over a month and still haven't got them in short supply but they did have so Marine AGM style with same specs as factory that have both side and top posts on them and they have been using them with no issues. and priced 303.99 so going to go with them.
    Goodysnap Thanks this.
  11. stark21
    129
    5
    Jul 25, 2010
    Virginia Beach
    well the new batteries they got me were Blue Optimum brand marine dual purpose AGM 's and yeah the ones I took out were the Odyssey xtreme# 31-PC2150, the specs aren't exactly the same 900CCA compared to 1125 and reserve capacity on the new ones are 155 compared to 205. but should still be enough power to run it, atleast the pete store said they would be good... and new ones are 75amp hours compared to 100
